Old 04-21-2007, 05:10 AM
peakprocess peakprocess is offline
Need Help!canada 89 dx cluster swap
CDM 89 dx cluster swap to usdm 89 si cluster
i can't find anything on a canada wiring diagram of the cluster
the plugs fit but the pinouts and color scheme are different from the usdm
Someone steer me in the right direction and please dont say "read..."
current dx cluster
[IMG]file:///e:/dcim/100canon/img_0105.jpg[/IMG]
swapped to this....
Old 04-21-2007, 01:03 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: Need Help!canada 89 dx cluster swap
it would help if your pics loaded... but on the back of the insrument cluster is a PCB (printed circuit board) just follow the traces on the board from the pins to wherever they go to on the guage cluster... it sounds alot more difficult than it actually is... you could either do that, or just poke and hope... not a recommended method at all... but it's your choice.. unless you can find a wiring diagram.
Old 04-21-2007, 09:57 PM
yes a cdm 89 civic dx wiring diagram would be great. anyone have one????
Ive traced the pinouts of my old cluster and the new cluster.
Still I am confused....
Old 04-22-2007, 02:24 PM
welfarepc welfarepc is offline
it doesnt work just by plugging it in?
Old 04-22-2007, 04:30 PM
only the right turn signal works. everything else turn wacky pack.
I read somewhere that if it not wired correctly i can blow a fuse.
Makes sense, but I still can't find anything or anyone that has done
this swap with my wiring configuration.
