Go Back   Automotive Forums Car Chat > Daewoo > Leganza
Old 04-21-2007, 02:42 AM
Archie C Archie C is offline
Red face Leganza ABS
Brake pedal judder when lightly depressing pedal (as if ABS kicking in) Pads and discs are fine. Sister had same problem with her VW Passat and said that a mechanic cleaned off ABS detectors.
It might be this as it occured after I used a High pressure Diesel Karcher washer - anyone else had this problem and how did you solve it?
Old 04-25-2007, 01:33 PM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Re: Leganza ABS
Exciter rings on the front axles are probably cracked. Cause intermittent ABS function. Must replace axles. expensive.
Old 04-25-2007, 02:39 PM
Re: Leganza ABS
Yeap
Jacked up and took off the wheels - was a broken exciter ring as you said - new CV required - £299 drivers side
thanks for the info
