Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-20-2007, 06:17 PM
Koenigferrari's Avatar
Koenigferrari Koenigferrari is offline
Electrical Problems
I am looking at buying a talon and i found a very clean looking one (N/A) for $3000CDN. Only problem is that it has electrical problems.
The owner says the car currently doesn't run. He took it to midas and they said it has minor electrical problems but they have to search for the direct cause. He also said the cost shouldn't be too much to fix.
I am a little bit skeptical about this and i am wondering if any of you have any ideas about what the problem could be or how much it would cost to repair?
Old 04-20-2007, 06:45 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Electrical Problems
There was really no need to make a new thread about the same car.
Anyways it could be tons of things. It depends on what the car is doing. will it turn over? Does it get fuel? Spark? Could be a loose or corroded wire, or it could be the ECU has gone bad. With electrical problems there is no telling how simple or difficult it will be to fix.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-20-2007, 08:21 PM
L-Spec's Avatar
L-Spec L-Spec is offline
Send a message via MSN to L-Spec
It's generally $60 an hour... and they can be in there for a long while, so I wouldn't even bother with a shop Maybe take it to someone you know that is more inclined with electrical work, or else find another DSM maybe.. just what I think. Good luck!
1992 Ẽfini RX-7 FD3S
Old 04-23-2007, 06:54 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I personally wouldn't get the car. Provided it is an electrical problem, you could have it fixed in 30 minutes, or you could be there for 3 months. Then again, you might find out the guy is lying to you and the problems are mechanical.
I would never buy a car that doesn't run, unless I can diagnose the problem before I buy it. But that's just my opinion.....and we know what they say about opinons.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-23-2007, 11:08 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
If it shouldn't be too much to fix, then he would have fixed it and sold a running car for more
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
