Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-20-2007, 09:22 AM
solar-eclipse solar-eclipse is offline
finnaly got the car!!!
I finnaly found the car, i bought a eagle talon tsi awd turbo 92', the only problem is all the valves are bent, how much money u think itll take to fix the valves, im gunna build this badboy from the ground up!
Old 04-20-2007, 11:06 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: finnaly got the car!!!
Wrong subforum. Unless you are selling or looking to buy something, you don't post here.
You may want to PM a mod to move the thread to Performance/Problem Diagnosis, I think either would work in this situation.
As to your question, the answer is it depends. Valves are relatively inexpensive from what I have seen, the expensive part is installation. If you can do it yourself (I'm guessing probably not) then it will only cost you parts, otherwise to have someone do it for you is where it will hurt your wallet and will vary depending on who you have do it. Call around to some shops in your area and get a few quotes.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-22-2007, 12:35 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I believe stock valves are 12 dollars a valve? Don't quote me on that but its somewhere around that price... Also I'm gonna move this to the Problem Diagnostics section...
So much for me taking a vacation from the moderating for a week.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-22-2007, 03:48 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
IIRC, valves are ~$16.....or the 420a ones are anyways.
95 Talon TSI AWD
97 Eclipse GST
Old 04-23-2007, 10:28 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
You can get the Stock valves from Road Race for $8 each. It is fairly easy to do for the most part, but if you are uncomfortable doing it yourself you would probably want to take it somewhere to do it. As far as how much labor is you would just have to ask the shop. Depending on how bad you bent the valves you might need new Valve guides and you for sure need new valve seals. Road Race sells all of that stuff here is the link.
http://www.roadraceengineering.com/eclengine.htm
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
