Old 04-19-2007, 08:01 PM
rjeffery rjeffery is offline
Coolent Flush
Anyone know what the best way to drain, flush and refill the cooling system and block is?
Thanks
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 04-20-2007, 12:59 PM
manlystanley manlystanley is offline
Re: Coolent Flush
Thanks
With my cars I always install the prestone backflush kit and use a garden hose. Also, instead of unscrewing the radiator drain plug, I just pull off the bottom radiator hose to drain it.
Best Regards,
Stan
1995 Plymoth Grand Voyager; 1998 Volvo S90, 2000 Ford Ranger, 2002 Dodge Grand Caravan.
Old 04-21-2007, 01:26 PM
Re: Coolent Flush
Thanks. I will look into that. Do you know if the kit flushes out the block as well as the radiator? Also, do you need to drain the water out of the block after flushing it?
Old 04-21-2007, 03:29 PM
Re: Coolent Flush
Yes it flushes out the block. Also, I drain the block/radiator again as you need to space to put in the coolant.
Best Regards,
Stan
Old 04-21-2007, 09:43 PM
guumbah's Avatar
guumbah guumbah is offline
Re: Coolent Flush
Best Regards,
Stan
If you have about 4 hours to wait, use the drain plug. Otherwise, ditto on the lower rad hose. Just did mine today (to replace the water pump).
2002 5.3l - Quadrasteer
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
Old 04-22-2007, 12:23 PM
Re: Coolent Flush
How do you drain the block? Does removing the lower radiator hose drain it, or do you have to remove the drain plugs in the block?
