Old 04-19-2007, 04:39 PM
gserve gserve is offline
Cleaning pulleys
How do you clean the pulleys. I have replaced the serpentine belt and the noise stops for a few months than comes back only when its cold and then goes away. Now it is squeaking all the time. Please Help!! Thanks Any other suggestions?
Old 04-19-2007, 08:58 PM
duke350 duke350 is offline
Re: Cleaning pulleys
You may also want to check the belt tensioner. They do wear out after a while. As for cleaning the pulleys, I would imagine they can be cleaned the same way you would clean anything else.
Old 04-20-2007, 02:37 PM
vtmecheng vtmecheng is offline
Unless something is spitting oil or antifreeze on the belt I would say you need a new belt tensioner. They are easy to replace and usually between $40 and $75.
Old 04-25-2007, 02:38 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I would maybe use pb blaster. Just be sure it doesn't eat away rubber!!!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 04-25-2007, 03:11 PM
muddog321 muddog321 is offline
AF -Advisor
The tensioner and idle pulleys have a sealed bearing (well kind of) and you can spray alittle silicon or other in them and if that stops the noise change it - will not stay quiet. Don't get spray all over the belt!
