Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-19-2007, 01:27 PM
hahapopcorn hahapopcorn is offline
carbon build up
Hi I have a 95 talon tsi awd w/ a 92 head. when my car starts to hit boost it starts jerkin and bogging like crazy, when i took out the spark plugs there was carbon buildup around the tip of it, when i cleaned it off it ran fine for a couple minutes untill it started to do it again with more carbon build up around the plugs. i use the NGK copper plugs and i changed them about 1.5k miles ago, i am also running stock plug wires (heard stock plug wires dont cut it for upgraded cars?) also when i tried to pull out the plug wire from the second spark plug the metal tip that goes into the plug wire was stuck onto the spark plug, if that might have anything to do with it? lol, the plug wires were changed maybe about 7-8 months ago. i have on the car a large 16g turbo and pushing 15 lbs. I thought it might possibly be a boost leak but i heard that if you do infact have a boost leak that the aftermarket boost gauge would not work correctly? o.O thanks
Old 04-19-2007, 06:14 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: carbon build up
You need to replace the spark plug that you pulled apart. That will cause some funny ignition issues.
95 Talon TSI AWD
97 Eclipse GST
Old 04-19-2007, 07:00 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: carbon build up
From what I have read, the stock plug wires should be fine under minor-moderate mods, granted that they are in good shape. Yours do not sound like they are. Might want to spring for some new plug wires (some nice aftermarket might be good in your situation) and while your at it might as well try some new plugs also, they are cheap. NGK BPR7ES gapped at .028".
Is there any oil in the spark plug wells or on the plugs at all when you pull them?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-03-2007, 12:20 PM
Re: carbon build up
My TPS sensor was un-plugged...i feel very very dumb.. Lol
Old 05-03-2007, 12:31 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: carbon build up
a big 16g at 15 lbs of boost, do you have any fuel mods?
***FUEL CUT***
Old 05-03-2007, 01:48 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: carbon build up
Yeah, the TPS could a real problem... though you might wanna do a tuneup on it, and a quick boost leak test, just to be on the safe side (that'll make you hit fuel cut and run rich enough to foul plugs )
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 05-03-2007, 01:55 PM
Black99GST's Avatar
Re: carbon build up
and do some fuel mods before you kill your motor... seriously!
Old 05-03-2007, 02:08 PM
Mikelb's Avatar
Re: carbon build up
yeah, I didn't even catch that... fuel would be a good thing here
Old 05-03-2007, 03:43 PM
Re: carbon build up
Yes, fuel mods are a MUST if you want to keep from blowing that thing to pieces.
95 Talon TSI AWD
97 Eclipse GST
