Old 04-19-2007, 11:59 AM
goalkprrr goalkprrr is offline
ses codes
97 blazer 4+4
ses light comes on and in drive transmission slips if manually shift no problem
i can shut it off after couple hours will drive with no problems but ses light stays on. i can reset computer to clear codes and runs fine for a while maybe few weeks then same problem codes that they found were p0740 and p1860 any ideas?
Old 04-19-2007, 01:07 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: ses codes
Here is the code list (thank you blazee, now bookmarked).
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 04-19-2007, 02:06 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: ses codes
think you forgot something . Here is the OBD 1 & 2 code list.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 04-19-2007, 02:18 PM
Re: ses codes
Touche.
Old 04-19-2007, 02:54 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ses codes
Codes are pointing to TCC PWM solenoid or wiring or fuse power to it problem.
Check all wiring and fuses and power feeds.
If the transmission is slipping bad your may have more problems.
What is transmission service and mileage and repair history?
MT
Old 04-19-2007, 04:35 PM
Re: ses codes
45,ooo miles and serviced regulary last tranny sercice was about a year ago.
it really is not slipping that bad
Old 04-19-2007, 04:36 PM
Re: ses codes
and like i said it does not do it all the time
Old 04-19-2007, 06:41 PM
MT-2500's Avatar
AF - Advisor
Re: ses codes
Go over the wiring and wiring plug in's and fuse box real good.
And remember 97 was a bad year for ign switch problems.
If you are losing 12 volt power to TCC solenoid it will at up and set them codes.
MT
