Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 10-15-2002, 09:07 AM
childe_r childe_r is offline
Intermitant oil pressure light problem solved
My oil pressure light was flickering on and off. I immediately thought " uh oh, my oil pump is getting weak. So I took it into BMW for repair. As it turns out when I last had the car detail they pressure washed the engine. When this was done, some water got into the oil senor cover. BMW took a Q-tp and contact cleaner, removed the water and NO MORE PROBLEM! SO if anyone else has this problem, it can't hurt to check this out.
Old 12-07-2002, 07:09 AM
newbe newbe is offline
Lightbulb 733i 83 oil light flicker
just info for another cause for oil light flicker at idle. check hollow oil feed bolts on cam oiler tube. mine was loose allowing oil to pump out instead of flowing through the oiler tube.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
