Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-19-2007, 10:45 AM
neilmac78 neilmac78 is offline
will these neon parts fit/work on my talon
SORRY IF THIS WAS POSTED BY ME ALREADY MY PC GOT A LITTLE PISSY WHEN I POSTED IT AND WAS NOT SURE IF IT WENT THROUGH AND POSTED
i have a 95 talon no-torbo with a 98 engine A/T and a 95 dohc neon m/t
my neon took a sh@t on me and will need a tranny replace and many many other repairs, so i desided to bring the talon out of its sleep of 3 years. I am getting a new tranny put in the talon as i write and wanted to see if my performance parts off the neon will work on the talon.
1) lightweight pully?
2) i put the msd coil and wires off the neon already is this ok? it works good so far
3) Mopar preformance ECU?
4)Fuel rail?
5) custom dual exhaust Catback. i know the high flow cat will not.
6)Aluminum radiator?
7) Front sway bar will not but will the rear? I would measure my self but i have a custom system in the trunk and cannot get to it untill i take that out.
8) any chance of the neon wings west side skirts fitting on the talon.
I have a bunch of stuff that i have to strip off the neon and wanted to see if anything will work on the talon before i sold the stuff.
thanks.
Old 04-19-2007, 07:08 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: will these neon parts fit/work on my talon
Most of those parts are going to be a trial-and-error to see. Most of us here do not use many neon parts for the 420a. I'm 100% sure the sideskirts will not fit, but as far as the rest of it I do not know.
95 Talon TSI AWD
97 Eclipse GST
Old 04-19-2007, 07:35 PM
I should have the talon back by the end of next week. i will test the ECU on it and see if it will work. i do know that it will connect.
my main concern was the underdrive pully and the radiator. i dont wanna take all that a part just not to have it fit.
i figured the skirts would not fit but just wanted to see if anyone had tried before.
i will post results of any parts that will work off the neon. maybe someone can use the outcome to get parts for there talon/eclipse.
Old 04-20-2007, 02:29 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Alot of the parts will not fit on your Talon from your Neon.
Now if you had a Stratus or Stealth they may bolt right up.
Like the man said though trial and error.
I had a Neon Sport Edition with the 2.0 16V Dohc it was the worst car
I had ever driven so I say F@#$ dodge.Good Luck
