Old 04-19-2007, 09:33 AM
GaryFenza GaryFenza is offline
Car Stalls
I just had the intake gaskets changed......and the car just randomly stalls at low RPM's when braking or coasting. The computer is not throwing a code or anythign. The "check engine" light does not come on. Whats the problem?? the Fuel pressure is fine. confused here. The Fuel pump has alot of miles on it, same with the filter, could that be the problem?
2003 Pontiac Grand Prix GT 3800 Series II V6
Old 04-20-2007, 08:06 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Car Stalls
Was it stalling before the LIM gaskets were replaced? It sounds like you may have an engine vacuum leak or low vacuum. Check all the vacuum connections at the LIM, throttle body, all sensors like MAP, purge and to the braking system.
Timeslip 08/12/06
AF Community Guidelines
