Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 04-19-2007, 08:40 AM
tank7725 tank7725 is offline
1992 crown vic prclems
Ok i need help. I have a problem with the brake light on my crown vic. It is on constantly. The parking brake isn't stuck on. I was wondering if this year was made with brake pad sensors or what might be the prob
Old 04-19-2007, 09:58 AM
reekor reekor is offline
Re: 1992 crown vic prclems
Try pulling the parking brake up by hand see if the light turns off. If that does not work there is a switch at the top of the parking brake pedal that might be stuck. Also check you brake fluid level these cars did come with a brake fluid level sensor that can trigger the light. If you do find the brake fluid level low check for leaks as pressure loss from a leaking line will also trigger the light.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 04-19-2007, 02:01 PM
Ok so i did all of that thanks for the help. I decided to take the wheel off and look at the breaks and it was the break pads that were wor down basicly falling off. I am now awear that there is a break pad sensor and if the break light stays on it is worth while to look at the breaks and or rotor.
Old 04-19-2007, 04:22 PM
Brake pad sensor?
Old 04-19-2007, 07:59 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
I suspect that the brakes are wasted like he said and the fluid level has dropped to below the sensor in the master cylinder. No pad sensors on any Crown Vic I know of.
Old 04-20-2007, 07:44 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Have to agree with you johnny. Has to he fluid level.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-20-2007, 07:45 AM
way2old's Avatar
TOKEN HILLBILLY
Have to agree with you johnny. Has to be fluid level.
Old 04-20-2007, 07:56 AM
Sort of like when the red oil light comes on to tell you that you're out of oil. LOL
