Old 04-18-2007, 10:47 PM
willl willl is offline
fitting tires
Probably a stupid question and everybody here knows it already but I have a set of tires on my vehicle and I have another set of 4 tires that I took of another vehicle. How do I find out if the 4 tires that I took of the other vehicle will fit on my vehicle. Does the numbers p245/75r15 mean anything. Anything else I should look for. Thanks
Old 04-18-2007, 11:20 PM
JeRzEy SiLvErAdO's Avatar
JeRzEy SiLvErAdO JeRzEy SiLvErAdO is offline
Send a message via AIM to JeRzEy SiLvErAdO
Re: fitting tires
The first thing you should look for, among others is the R15. The R15 on the tire is telling you the rim size in your case 15inch.. If those #'s are not the same on the 2 sets of tires, you wont be able to mount them..
2002 Z71 Silverado 4x4 5.3
Gibson Catback Exhaust
K&N 77series Intake with AEM Dryflow airfilter
Hypertech Programmer
Jet MAF
Aeroforce Interceptor Gauge
8500K HID's
Old 04-19-2007, 07:42 AM
rjeffery rjeffery is offline
Re: fitting tires
245/75/15. 245 is the width of the tire in millimeters. 75 is the height of the sidewall. It is a percentage of the width. So the height on this tire would be 265mm * 75% = 198.75mm. And 15 is the diameter of the rim.
http://www.discounttire.com/dtcs/infoTireDimensions.dos
Like Jerzey said: You can only mount a 15" tire on a 15" rim
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 04-20-2007, 12:54 AM
Re: fitting tires
If you want to convert all that into inches.....Just divide by 25.4opcorn:
Jet MAF
8500K HID's
Old 04-20-2007, 11:17 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: fitting tires
Don't forget that "R" means radial. I believe Discount or Tire Rack has a "Tire Dictionary", but I couldn't find it.
*Under Construction - New sig to debut*
Old 04-21-2007, 04:55 PM
isie isie is offline
Re: fitting tires
also make sure you have the right ply 10ply for the hd, 6ply for 1500 and normal driving
