Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 04-18-2007, 09:00 PM
mtc601 mtc601 is offline
2 In 1 Help,programming Keyless & Gas Gauge
I recently bought a 1991 Eighty Eight Royale and it sat for months. I recently replaced both car battery and key fob batteries with new. The key fob seems to be the original(FCC GQ43VT1 DOC). Instructions on reprogramming is needed greatlye the driver's lock cylinder isnt working.
Please specify name and location of componets and/or if there is any part that needs to be removed, and please describe components in detail.
I also have a problem with the gas gauge, once I turn on the accesories the gauge reads 1/8 full, once I start the engine, the needle drops back to Empty. I've still tried to pump gas into it but the pump stops(indicating that the tank is full) and once I get back in and turn the car back on, the gauge still reads empty.
Help is GREATLY APPRECIATED
Old 04-19-2007, 10:23 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: 2 In 1 Help,programming Keyless & Gas Gauge
Leave key off
Jumper pin A to pin G with a fused jumper (3A)
Doors will lock and unlock
Pres the UNLOCK button on the remote
Doors should lock and unlock again
if you have more remotes press their unlock button (up to 4)
remove jumper wire
________|________
[F] [E] [D] [C] [b] [A]
[G] [H] [J] [K] [L] [M]
_________________
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 04-19-2007, 10:03 PM
Where is the location of where the jumper pin goes(A, B, C...)
Old 04-20-2007, 07:56 AM
razr_88 razr_88 is offline
Send a message via Yahoo to razr_88
usually underneath the dash on the driver side. it should be fairly easy to spot as it looks like something youd see on the back side of a computer
Old 04-20-2007, 06:34 PM
I've found this but no progress, there aren't any metal pins inside any of the slots except A B and M
Old 05-02-2007, 03:27 PM
Jrs3800 Jrs3800 is offline
Open the glove box and look behind the Yellow trunk release button, there should be a connector attached if you have Keyless entry...
If its there all you have to do is ground out those 2 tabs and the system will cycle the locks and trunk release letting you know it ready to learn the remotes... Once you have programed the remote or remotes, remove the grounding tab you used..
Good Luck
