Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 04-18-2007, 07:59 PM
Divorce Court Dan Divorce Court Dan is offline
Send a message via AIM to Divorce Court Dan
Exhaust Manifold
I'm looking for someone that has done exhaust manifolds in the crown vics. I might attempt to do mine. Just wondering if you have any tips. I do have torches to heat up the studs. Just kinda wondering what the easiest way to get to them is? Thanks
Old 04-19-2007, 06:35 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Exhaust Manifold
The easiest way to swap them is to remove the motor. Other than that, raise it up as high as you can, you may need to loosen the motor mounts if they are weak to give enough clearance to remove them. Then it is just a slow process. Be prepared for some of the exhaust studs to break or already be broken. It is not a fun job at all. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-19-2007, 07:43 PM
Ok. Thanks. Maybe I'll just deal with it.
Old 04-19-2007, 08:01 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
It will eventually get worse and if you keep going on it, other studs may snap off. way2old is right about removing the engine to make it easier. That job is a bear.
Old 04-24-2007, 03:25 PM
1996Chreokee 1996Chreokee is offline
make sure to use anti seize or a special bolt for replacements.. its worth the investment in the event you have to take it apart again down the road
let us know what you do
