Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-18-2007, 07:59 PM
nick96gst nick96gst is offline
problem with engine cutting out
Hi new to this sight think I screwd up already writing a post srry if i did. Got a 96 gst 2.0 Brought used 6 months ago. been running fairly good. It just started to cut out at higher speeds above 60 or if I get on it at lower speeds. I have changed plugs, wires and fuel filter. No codes at this time. Compression is 180, 178, 178, 180. I am thinking fuel filter but. Any help would be appreciated. Thanks
Old 04-18-2007, 08:12 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: problem with engine cutting out
Thanks for posting one in the correct subforum, but if you have already posted one previously, there's no need to make another one. Just edit your last one and say that you didn't realize you made the mistake, and a mod should gladly move it for you.
95 Talon TSI AWD
97 Eclipse GST
Old 04-19-2007, 08:10 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Compression looks good. What exactly do you mean by "cuts out". Is it a sputter, or does it feel like you are hitting a brick wall?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-19-2007, 12:33 PM
trap95 trap95 is offline
replace ecu go to dodge dealer and put a r in front of number stamped on old compute should be 185.00 for reman my 95 eclipse in now running good
Old 04-19-2007, 12:38 PM
I HAVE 95 MIT ECLIPSE WHILE DRIVING CAR WAS STALLING, SOMETIME,AT LIGHT OR ON THE ROAD STARTED TO GET WORST. I REPLACE THE ECU UNDER HOOD,WENT TO DODGE DEALER AND PUT A R IN FRONT OF NUMBER STAMPED ON OLD ECU. THIS IS A REMA PART FOR ABOUT 185.00 . WHEN I WENT TO THE MITS DEALER THEY ONLY HAD USED FOR 500.00 .GO TO DODGE DEALER WITH MUNBER ON OLD PART AND PUT A R IN FRONT . MY CAR IS NOW RUNNING PETTY GOOD
Old 04-19-2007, 06:12 PM
Trap95, please type in complete and coherent sentences so we can understand you better. I don't know what you mean by putting an "r" in front of it, but if you go to a strictly Dodge dealer, they will not know what you're talking about. You need to go to a Chrysler dealer because Eagle is a division of Chrylser, not Dodge.
Also I think his problem is not random shutdown, as he said it only does it at higher speeds and not just at any random time.
95 Talon TSI AWD
97 Eclipse GST
Old 04-20-2007, 05:39 PM
JScharF JScharF is offline
My guess by what he means is say your product number is xxxxxxx then apparently dodge has the same part... but Rxxxxxxx
Old 04-21-2007, 08:34 PM
on the old ecu their is a number stamped on it ,go to a dodge dealer and put a R IN FRONT OF THAT NUMBER ( LIKE R4454966) THIS IS A REMA PART FROM DODGE IT IS HALF THE PRICE ,I WORKED FOR DODGE FOR 22 YEARS
THATS WHAT I MENT.
Old 04-28-2007, 01:46 PM
hey thanks for the help but i just changed the plugs and also changed the fuel regulator and it still cuts out
what is the timing advance suppose to be at on the 96 eclipse becuase when my car is idleing it jumps go 7 to 10 then when im driving it it 3000 rpm with 33 degress
need help
thank you !!
Old 04-30-2007, 08:16 AM
Your timing is normal. Under a light cruise, I'll see anything from 22 degrees up to 35 degrees depending on how much throttle I'm giving her.
What plugs did you use and what gap did you set them at? Also, have you done a leak check?
1997 Spyder GS-T
5-Speed
Old 05-01-2007, 05:24 PM
I brought what everyone suggested ngk---7 plug. gap at .028. Going to do a leak test this weekend. Trying to find the exact way to do it. do you remove cold intake, seal and pressurize turbo intake too about 20psi. Doesn't the air escape thru valves?
Old 05-01-2007, 05:39 PM
http://www.vfaq.com/mods/ICtester.html
It shouldn't be able to get past the throttle plate so no, it wouldn't be escaping through the valves.
95 Talon TSI AWD
97 Eclipse GST
Old 05-02-2007, 07:00 AM
Definately, it happens all the time. The best place to have the motor is at 30 degrees ATDC to prevent valve overlap.
1997 Spyder GS-T
5-Speed
