Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-18-2007, 07:50 PM
nick96gst nick96gst is offline
car cuts out at higher rpm/speed NEED HELP!
Hi everyone new to this sight. need help!!
i have a 96 eclipse gs-t 2.0 Cuts out at higher speeds 60 and above or lower speed if i get on it. changed fuel filter, Plugs, Wires. The Injectors and coils were check and ok. No codes at this time. Compression check showed 180, 178, 178 and 180. I am thinking fuel pump but haven't checked yet. Any suggestions would be appreciated.
Old 04-18-2007, 07:56 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: car cuts out at higher rpm/speed NEED HELP!
Could you please put any modifications in your signature so we know what exactly you have done to your car. Without that info it is hard to tell. Could be a number of things. Is it at a certain speed, or maybe at a certain rprm. Does it only happen when you are putting the pedal to the floor?
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 04-18-2007, 07:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Could you elaborate more on what "cuts out" means? Do the rpms just drop down to nothing and then pick up again after the car slows down? Do the rpms just stay the same and the car just won't go any faster? Does the car physically "shut down"? A little more elaboration would greatly help.
95 Talon TSI AWD
97 Eclipse GST
Old 04-18-2007, 09:20 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Do you recall what plugs you put in and what gap you set them to? Many times people will put platinum or off-brand plugs in and this tends to cause problems, or they forget to gap them properly.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-18-2007, 09:23 PM
the aftermarket parts i have in my car are:
turbo not sure what kind but its pushing about 16 lbs of boost
turbo xs blowoffvalve
turbo timer
greddy exhaust system
basically my eclipse in 2nd through 5 gear cuts out, like in 2nd about 5k its cuts out or studders and then when i shift to 3rd it well gain about 10mph or so then cut out ot stuuders again, then ill shift to 4th etc. and car tops out at about 80mph
thanks for help
if thats not enough info ill try to explain better
Old 04-18-2007, 09:26 PM
the problem started before i got new plugs but,
i got bosch platinum pre-gapped
if that helps
Old 04-18-2007, 09:27 PM
Put in some regular NGK plugs, that should get rid of the studder as it starts boosting, if that's the problem.
95 Talon TSI AWD
97 Eclipse GST
Old 04-18-2007, 09:29 PM
NOFX0617's Avatar
Yeah I would also suggest the NGKs...at the same time you should find out what turbo is on the car...you could be hitting fuel cut if you are on the stock fuel system.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 04-18-2007, 09:49 PM
Thanks I will get the ngk plugs tomorrow and try them, but i been running with these after market parts for 4 months and no problems. this just started two weeks ago and i started replacing the obvious parts first.
Old 04-18-2007, 10:02 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
just dropped this in another post, seems like a boost leak. check all the IC pipes and especialy around the BOV. do you have aftermarket IC pipes?
and the NGK's are BPR7ES's. gap to .028. stocks are the BPR6ES's and the 7's are better [1 step colder]
Old 04-19-2007, 08:14 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Definately get rid of the Platinum plugs. They are not good for a turbo charged vehicle and will cause all sorts of problems. They retain more heat than standard copper plugs, mostly for the benefit of a longer plug life. This normally causes knock because of the newly created hot spot in the cylinder. Knock = timing loss = inconsistent acceleration.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
