Old 04-18-2007, 08:21 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
Cost for repairs.....?
“… Determined cause to be broken crankshaft position sensor. Cause of broken sensor is excessive crankshaft end play (approximately .050 of an inch), which is enough for the pick up plate to come out of alignment and break the sensor. Engine lower end will have to be replaced.”
this is what i was told needed to be fixed.. any one know about how much this would cost? (this is not my car so i didnt have this info said to me i was looking to buy the car and was just wondering if it would be worth my time at all, its a 1998 gsx)
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 04-18-2007, 08:39 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Cost for repairs.....?
Well you my friend have what we call Crankwalk which is also called Thrust bearing failure. Pretty much the motor is done. If you would like to keep the car you can either get a whole new engine from the same year, but your best bet would be to do the swap to an early Eclipse engine from the 90-92 models. I am currently going through the same thing so I feel your pain.
There are 2 good reads here about crankwalk and doing the swap to the other block
http://www.magnusmotorsports.com/tech/index.htm
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 04-18-2007, 10:08 PM
WaFFeL WaFFeL is offline
How much is he asking for the car?
Old 04-18-2007, 10:28 PM
5k, do u want the autotrader link? ill show u
Old 04-18-2007, 10:32 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
That sounds really high for a car with a f*ed motor. Yea post a link.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-18-2007, 10:33 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
What does it have for mileage? And what condition is it in?
95 Talon TSI AWD
97 Eclipse GST
Old 04-18-2007, 10:34 PM
http://www.autotrader.com/fyc/vdp.js...e=&cardist=314
i figured that was asking alot for the car but thought id ask here to make sure.
Old 04-18-2007, 10:36 PM
Holset powered 420a
looks like a nice car. Not worth 5K, I see the FMIC and the gauges so I wonder what else is done to the car.
98 Eclipse GS Turbo
2001 BMW 325i - DD
if u didnt check the link it has 79,000 miles and looks in good shape.
Old 04-18-2007, 10:38 PM
yea it has some upgrades, not sure of what tho. but what do u think would be a good offer for it. i really want a gsx and im having a hard time finding one i can afford thats in good shape.
Old 04-18-2007, 10:40 PM
Killa's Avatar
Killa Killa is offline
but not running , I aint buy a car that is not running.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 04-18-2007, 10:42 PM
Yea ik =( i want one that runs good but as of now i cant afford much so im just looking for a gsx in not bad shape. after i sell my car and my boat ill be able to afford some changes/fixes so.. we'll see what happens
Old 04-18-2007, 10:43 PM
NOFX0617's Avatar
Its up to you man. I would price out how much you think you would spend on replacing that motor. I myself found a 6 bolt block from a friend here in town for 150 bucks. It needed some work but in the end it isnt that much to replace it. If you decide to do it then I would try and talk him down a little bit. It would be nice to see a mod list from the guy. Also buying a car that doesnt run isnt usually the best idea. You never know if that is the only problem. I know they are rare but sometimes you just got to wait it out and find the one you really want. I waited it out for about 6 months looking for one and when I finally found one in good shape with low miles and no mods, it just happen to be the color I wanted...Good luck with your decision.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 04-18-2007, 10:45 PM
Ight here is the list of mods.
ENGINE: Mobile 1 1030 every 3,000 miles. Engine/trans parts have less than 15,000 miles on them, most have less than 5,000 miles.
BOTTOM: 2.3L stroker, Crank lightened/turned 10 under, All gaskets Topline with 3'copper head gasket, clevite rod and main bearings, Balance shaft eliminated, Crower rods, Prothane motor mounts.
HEAD: Boared to 20 over, JE pistons(20 over), Titanium retainers, dual valve springs, 1mm over ferrea valves/guides, revised lifters, Topline Rockers, Magnacore plug wires, Blue Kevlar Timing belt(4000mi), Evo spark plugs.
ENGINE MANAGEMENT: Haltech E6K ECU W/laptop plug-in, Dell Laptop.
INTAKE/EXHAUST: HKS intake, 3' Custom cat back exhaust, 3' High flow cat, 3' down pipe.
TURBOFUEL: Ported 16g Turbo w/o2 eliminator housing, All new turbo gaskets, Greddy Intercooler, Tial 41mm wastegate, Greddy Type R Blow Off Valve, 550cc Injectors, Wallbro 255lpf fuel pump.
ELECTRICAL: Greddy Turbo Timer, Autometer Air/Fuel gauge, Blue Colbalt boost, oil pressure, coolant temp, and exhaust temp gauges.(lights on gauges controlled by switch on lower dash board), new battery DRIVETRAIN, ACT 2100 Clutch & Plate, Fidanza Flywheel, Transmission rebuilt around 15,000 miles ago.
EXTERIOR: 17" Momo rims, 4 New Eagle 1 RSA tires, JDM black projector headlights, Front Clear corner lights.
OTHER: BRAND NEW high output alternator, New Tires have Less than 4000 mi on them, Blue Kevlar timing belt has less than 6000 miles, New Coil packs and Transistor pack w/ less than 4000 miles, New Starter less than 6000 miles, All new no-squeak engine belts, Inspected 4000 miles ago.
There are likely a few modifications not listed. The sunroof works perfectly. The turbo spools are very fast and are set at 15psi. The horsepower is not known because the tuning has been done from a laptop while driving around using Haltech software. It is assumed that the horsepower is between 300 and 400 based on knowledge of similar cars. The laptop comes with the car as well.
Old 04-18-2007, 10:47 PM
Offer him $3700 and see what he says. I personally wouldn't pay more than about $4k for it.
EDIT: Is that the parts list thats on the car, or what you want? That's one HELL of a mod list, seems almost too good to be true.
95 Talon TSI AWD
97 Eclipse GST
