Go Back   Automotive Forums Car Chat > Volvo > 240
Old 04-18-2007, 05:04 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Where is fuel pump relay located?
Where can i find the fuel pump relay on my 1980 242Gt non turbo?
I have been told that these go out often and i should carry a spare.
Was wondering if this is true.
Thanks
Al
Old 04-20-2007, 10:51 AM
DDubuque DDubuque is offline
Re: Where is fuel pump relay located?
it's located under the glove box,take down the kick panel,there should be 2 plastic screws and a rubber garmet that goes around your heat duct,the relay is either white or green,Volvo used both type relays,i have opened up the relays and repaired them,check for broken soldier on the board.
Old 04-20-2007, 03:43 PM
Blt2Lst's Avatar
Thanks for the info.
Are these relays prone to failure?
Al
Old 04-20-2007, 09:28 PM
yes,i've done alot of them over the years,like i said before,take it a part and see if theres a brake in the soldier,if you see one and have a soldiering iron you can just soldier back together and try it,hope this helps
