Need a little help with a 99 intrepid 3.2 . I had a p0123 code so I replaced the throttle position sensor, now the thing is coding p0122. Does the sensor only go in one way? I had the auto parts store double check that it is the correct sensor. Anybody got any ideas?
Re: Help!! p0123 now p0122 99 intrepid
possible causes for code:
sensor signal circuit shorted to ground TPS failure (where did you get it from?) loss of 5 volt supply (probably not) PCM failure corrision or problem with connector or wires. the reason it shows low voltage code is because the TPS voltage at the PCM went below .2 volts for more than .7 seconds. |
Thanks for your input, evidently there's 2 different sensors that fit the 3.2 and I got the wrong one. They look identical, but they turn in opposite directions. I had to lay them down side by side and compare operation.
Ok, another new sensor did the trick. The number on the box was right but evidently someone switched the sensors in the box. It bolted on fine, but it was the wrong one.
Trouble codes for all Intrepids 1993-2004
GA_googleFillSlot("Forums_ROS_300x250_noad"); Hello everyone, I've created this thread to help out those who have a Dodge Intrepid or any Daimler-Chrysler vehicle that was built from 1996-present. If you have a check engine light and need to know what the code is, visit this website to give you the answer(s) to your code issues. The website is: http://autorepair.about.com/cs/troub...l_obd_main.htm. If you have a 1993-1995 Intrepid and you have a check engine light, you can find out what the codes are by following this process: 1. Turn the ignition key on/off 3xs ending in the ON position 2. Watch the "CHECK ENGINE" light and see if it flashes. 3. If it flashes twice then pauses and flashes again another 4xs, that's a code 24, for example. You have put the computer in diagnostic mode and it will now display any codes that have been stored in memory. Here is a list of all codes that can be displayed and what they mean: 12- Problem with stand-by memory circuit. Direct battery input to controller disconnected within the last 50 ignition key-ons. 13- Indicates a problem with the MAP sensor pneumatic system. 14- MAP sensor voltage too low or too high. 15- A problem with the vehicle speed sensor signal. No speed sensor signal detected during driving conditions. 16- Loss of battery voltage 17- Engine coolant temperature indicating engine temperature cold too long. 21- Oxygen sensor voltage not fluctuating. 22- Coolant sensor voltage too high or too low. 23- Throttle body temp sensor below acceptable parameters. 24- Throttle position sensor voltage too high or too low. 25- Automatic Idle Speed motor detects a shorted condition in one or more circuits 26- Peak Injector current has not been reached. 27- One of the injector control circuit output drivers does not respond properly to the control signal. 31- Problem with the canister purge solenoid circuit 32- An open or shorted condition detected in the EGR transducer circuit. 33- Air conditioning clutch relay circuit open or shorted. 34- Open or shorted condition found in the speed control vacuum or vent solenoid circuit. 35- Radiator fan relay circuit open or shorted. 36- Problem with the air switching solenoid circuit. 37- Open or shorted condition detected in the torque converter unlock solenoid circuit. 41- Problem with charging system. Voltage below 11.75. 42- ASD (Automatic ShutDown) relay control open or shorted. 43- Engine misfire in one or more cylinders. 44- Ambient/Battery Temperature too high or too low. 45- Transmission temp sensor not indicating warm condition. 46- Charging system voltage too high. 47- Charging system voltage too low. 51- Oxygen sensor signal indicates a lean condition. 52- Oxygen sensor signal indicates a rich condition. 53- Internal PCM failure. 54- No cam signal to PCM. 55- End of code message. 62- Unsuccessful attempt to update EMR mileage in the controller EEPROM. 63- PCM failure. EEPROM write denied. These are all the codes for most 1993-1995 and a few 96 and 97 Intrepids. If you need any others if I missed them, please let me know. |
