Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-18-2007, 02:10 PM
thebigreddog16 thebigreddog16 is offline
Unhappy rough idling
I have a 2000 Rodeo LS with +120,000 kms and just got a recent tune up. I have had no serious problems with it before. Now when im stopped at a light, it starts to idle pretty roughly. When I start to accelerate it hesitates, stutters a bit and then finally goes. Any ideas? Thx
Old 04-18-2007, 02:50 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: rough idling
I would start out with the simple stuff. Clean the PCV and EGR port and Tube (read up in the FAQs).
If that doesn't help, you may want to replace the fuel filter.
after that then it would think it is the intake manifold gasket (very common, I've had mine replaced 2x in my 2000; more info also in the FAQ's).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-18-2007, 04:49 PM
660Ryder 660Ryder is offline
Re: rough idling
Check the air filter...(installed correctly, no obstructions, et cetera) Squirrels made a mess of mine at one point in time, leading to some of the same symptoms you are experiencing.
Old 04-18-2007, 10:11 PM
surferfletch surferfletch is offline
Re: rough idling
Did you have the tuneup done because it was running poorly, or just because it was due? If it started running roughly after, I'd make sure the correct spark plugs were used.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
