Better Head?
I have a 98 Integra GSR with a B18C1, and i know Typr R's have B18C5's, and im pretty sure the C1 and C5 head is interchangeable, but i was wondering.
Is the C5 head faster or better in any way than the C1? And would it be effective to switch to a C5? |
Re: Better Head?
The ITR head comes with more aggressive cams, has a mildly ported head, and shares the same intake manifold bolt pattern as the B16B and B16A (different than the B18C1). The cams will help performance a little. The mild P&P helps it flow a little better. And the IM bolt pattern makes it a little cheaper when purchasing aftermarket IMs. The B18C1 IM is designed to give good low end torque and then opens up ("secondary butterfly"/Intake Air Bipass) to give good high end power at vtec engagement. The other vtec B-series IMs don't have this feature. Also the B18C1 head gives the engine a slightly higher compression ratio (smaller combustion chamber), so switching to the ITR head will lower the compression (you'll lost a little power from it). So honestly you won't really see a whole lot of difference by swapping.
Re: Better Head?
alright thanks
i just always heard the Type R's were faster, and figured it was the head diffrence, but id much rather prefer low end torque and the higher compression, for right now |
Re: Better Head?
IMO the power gain from the head swap is not worth the cost....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
