Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-18-2007, 12:31 PM
bag91's Avatar
bag91 bag91 is offline
Exclamation Some interesting tranny issue.....
For the longest time the cars been running great but lately shifting out of second gear the idle jumps. Let me explain, Im driving and I almost wot, as it shifts from 2nd to third it almost sits in neutral, lets the rpms jump some then shifts to third. This occurs in a matter of seconds but its bugging the crap out of me.
And it mostely occurs when its been driving alot....warmed up.
Anyone have any ideas?
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 04-18-2007, 12:51 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Some interesting tranny issue.....
How's the fluid look'n?
Also, check the vauum line for the modulator.
Old 04-18-2007, 08:56 PM
83T/A98Blazer 83T/A98Blazer is offline
Is it the 91 Camaro you're talking about? 700R4? Rebuild the valve body and 2/4 servo with a "shift correction" kit. It should slam 2nd after that.
Edit: Oops, my mistake. I thought you said 1-2 shift. I'd guess your 3-4 clutch is on it's way out, sorry.
Old 04-18-2007, 10:07 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
yea, the 2-3 is definately slipping.
Old 04-19-2007, 03:57 PM
bag91's Avatar
So whats it gonna do in the future and how do I fix it?
Is it more then likely something other than the vacuum modulator, because all the other shifts are sweet and smooth.
Well this kinda sucks because with the gears, 2nd to 3rd is the brunt of torque.
K/N filter
3.73's
B&M Megashifter
180 thermostat
3" exhaust cutout
Old 04-20-2007, 12:00 AM
Morley Morley is offline
No such thing in a "modern" transmission.
Old 04-24-2007, 09:22 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
just sounds like the tranny is getting hotter than it likes...(not uncommon for hard WOT driving). mine did the same when i had the V6. I'd add a tranny oil cooler.. the B&M model is only around $40. route it thru your radiator (it comes with instructions) and I would also add some B&M Trickshift... it does work, well. doesnt sound like your tranny is in bad enough shape to warrant taking it apart, or a rebuild. a tranny oil cooler is a good idea anyway.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 04-25-2007, 02:33 PM
bag91's Avatar
Are there any down sides to a tranny cooler, isnt it already plugged into the radiator?
K/N filter
3.73's
B&M Megashifter
180 thermostat
3" exhaust cutout
Old 04-26-2007, 08:29 PM
no downsides to a tranny cooler.... takes ~40mins to install. decreases tranny fluid temp, increases tranny life. any high performance car with an auto tranny should have one.
yes ur tranny is already plugged into the radiator. u can run the tranny lines thru the radiator, thru the tranny cooler, or thru both. (see install instructions when u get it).
