Old 04-18-2007, 12:11 PM
hawk362's Avatar
hawk362 hawk362 is offline
Biggest/Safest Twin Turbo Setup for VR4
I always hear about the 15g turbos being upgraded on vr4's being the biggest setup and being able to boost well over 23psi but Ive always wondered whats the biggest and safest twin turbo setup you could have on these cars, with the correct accomodated fuel upgrades, right air/fuel setup, and necessary mods. Just in case we all won the lottery and wanted to have that 1 really quick vr4 in their garage that put murcielago's to shame.
Old 04-18-2007, 12:42 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Re: Biggest/Safest Twin Turbo Setup for VR4
With the proper amount of mone anything is possible.. So who knows
Also are we talking bout TD04 based turbos or just any turbo... When i was 3si the other day 19t seem to be the love of td04 based turbos.
Old 04-18-2007, 01:54 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
what do you mean by "safest"??
anything can be done with enough money.
as far as not blowing your engine, the safety/huger power is all in the tune.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-18-2007, 02:31 PM
Hotshot8792 Hotshot8792 is offline
There's really no "safest turbo". All turbos have the same function, they compress more air into your cylinders. Now as far as being safe for your engine all depends on how you use the turbo, how you tune your car, and what kind of condition your engine is in etc. Now if your wanting to use a turbo that uses the stock housing that requires basically no extra work other than just replacing turbos, the biggest replacement is the 19T, however I still like the DR650R's for some reason. They're both available from dynamic racing. Basically after those two you will have modify other parts of your car. Other things I recommend doing as well when upgrading turbos is upgrade injectors, fuel pump, intercooler, fuel management.
As far as what our engines can handle, well so far they can handle anything you throw at it. No one has reached the limits of it yet.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 04-18-2007, 02:41 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Its all about the tune for sure.. IMO engine managment is more important then the size of the turbo.. I haven't herd much about the 19t's anyone have a link on them?
Old 04-18-2007, 03:07 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
15g's are not "big" by any means.
They are tiny little turbos.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
