Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-18-2007, 10:22 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Vibration in steering wheel
Hey;
I've been noticing while driving, lets say on the expressway doing 60, if I turn the wheel slightly to the left, there is a vibration in the steering wheel. It doesn't do it as much when to the right, however I believe it's still there. When going left then, it makes like a rough sound. It's hard to explain. But there's a different sound coming from the suspension or wheels then. But it goes away when the wheel is back straight again. Any ideas on what this can be? Thanks.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-18-2007, 10:24 AM
Killa's Avatar
Killa Killa is offline
Re: Vibration in steering wheel
Originally Posted by david-b
Hey;
low balljoint ? my did kinda same thing few week ago, then I got it check and replace by dealer.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 04-18-2007, 10:41 AM
david-b's Avatar
Dave is THAT guy
And as I know you now this... I've had the lower control arms/joints replaced already. New tires and alignment also.
75 Monte Carlo
Old 04-18-2007, 11:31 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Ya, why bother having a seperate forum to keep the main one clean if you're just going to advertise your own stuff. Please lock this before I get really angry.
so why do you do the same thing is what has me totally confused?
Old 04-18-2007, 11:39 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
What's your PS fluid look like??? if it's murky, try replacing it... if it absorbs water, that can be bad news for your steering...
I'm going to have to say check the bolts in the control arm, make sure they are more than tight...
Also, check the alignment (I really believe the problem lies here)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 04-18-2007, 12:43 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
My guess is to prove a point.
David for your problem, I would also check the PS fluid and make sure it's all good. Does it do it any other time except when turning left slightly at that speed?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-18-2007, 01:05 PM
david-b's Avatar
Dave is THAT guy
That's when it's most noticable. Like anything above 50 is when you really feel it and hear it, but it does do it always. I will drain the PS fluid probably this weekend and refill. See what's going on with that. I think it may be something else though. And there's still that popping sound when I make turns coming from the front also still. Been doing that since I got the car.
I may take it to my shop to get it checked out. I'm not a true DSMer apparently so I know nothing.
75 Monte Carlo
Old 04-18-2007, 01:12 PM
Mikelb's Avatar
that sounds like cv joints...
your other problem sounds like it might be alignment. I suggest checking the bolts in the control arm first though... I've had one come loose at 60MPH and that's no fun... especially when you have no f'in idea what it was.
So, I suggest, checking all suspension bolts, and getting aligment checked...
Old 04-18-2007, 11:21 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
i would first take it back to the guy's that did the suspension work and make sure that everything is still tight. you never know if something has come loose or was not Tq'd correct.
also it sounds like it may be a balance issue. one of the balance wieghts may have come off and your tire could be out of balance. symptoms are there, happens at higher speed where the force would be most noticable in the turning moment. ever held a bycicle tire while it was spinning and moved it around? same thing.
as for the sound that has always been there, worry when it goes away. that will probably be the bad note.
best.
