Old 04-18-2007, 01:08 AM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
Ramps or a pit ?
Had the car up on jack stands a few days ago. My wife came into the garage for something and said I needed "one of those hole thingy's" in the floor. I told her that I was going to build a set of ramps because I thought she would kill me if I cut the floor for a pit but she said it sounded like a good idea.
What are your opinions? Ramps or pit?
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 04-18-2007, 02:09 AM
goldz28's Avatar
goldz28 goldz28 is offline
Re: Ramps or a pit ?
Are you talking about a hydraulic lift? If you are I think one of those are nice. A pit would have some nice things to. You don't have to worry about the car falling on you. But if you have kids you would have to keep it covered. I would go with the ramps or lift.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 04-18-2007, 08:16 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
ramps are good for a variety of things. Only thing is when shopping around make sure:
A- they are plenty wide enough to accomodate a variety of tire widths
B- The platform stops are high enough to stop the tires from going over when a spotter is not available, such as what I almost did last weekend.
Old 04-18-2007, 08:43 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
don't forget that ramps are a lot cheaper that a lift or pit. just make sure you get a set thats well built.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 04-18-2007, 10:05 AM
goldz28's Avatar
Dylan what kind of ramps do you have? Pic?
rob67gmc's Avatar
A lift is not an option for me. Besides, I don't like a lift or a ramp that's too high because you can't work with someone under the hood and someone under the car at the same time. I know a pit would be a lot of work. I can build ramps myself, they just have to be able to be moved out of the way when not in use. I have an idea of how I would make the ramps but does anyone have any plans or pics.
Maybe I could install a drive-on lift over a pit and have it all. LOL
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 04-18-2007, 10:08 AM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
One thing you have to be sure about with ramps is that your able to acutally get your car on them without ripping up the front end. A guy I went to school with in HS made some ramps for his '98TA, they turned out to have to much of a rise in them and the car couldn't go on.
As for making them, start with a piece of paper and a pencil and just draw some out. Make sure to have bracing, to much is better than not enough. Then get some steel and a welder.
Old 04-18-2007, 10:14 AM
goldz28's Avatar
sounds like a lot of work to me. lol
Old 04-18-2007, 10:18 AM
Yep, just use a jack and some jackstands.
Old 04-18-2007, 10:48 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
i'd go with 2-post lift. they're not actually that expensive. two of my mates live together and their garage has 3 5-ton lifts in there. and when they need someone working underneath and somone you can get a platform with step-ladder on castor wheels. i've used the one my friend have. you just get it in place, lock the wheels and work away.
http://www.americasprideonline.com/9...1-.ViewProduct
that can hold 9,000lb and only costs $1,295. lifts are far better than ramps because you lift the car by the chassis/monocoque instead of the tyres, so removing wheels and working with the drivetrain is a lot easier.
if that's not an option, then like the others said, jackstands. you can get low jackstand, 2ft jackstands, 12-ton jackstands.. and with that you can get under the car easily, and someone can work on the engine from the top easily too.
Seatbelts Saved My Life
Old 04-18-2007, 12:43 PM
wrightz28's Avatar
Got em from a old mechanics garage sale, overall standard driveups, but are capable of handling small trucks and the ramps detach from the stand for space saving storage
Old 04-18-2007, 04:04 PM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
I have ramps and have used them, but they didn't really lift it high enough to do much, i could barely fit under to change the starter. When i backed off, they tore the ground kit off the passenger side in front of the wheel. That was a PITA to bend back and reattach. I've used my friend's pit and i LOVED it. He could look down through the hood and i could be down there working, made things nice, especially for changing oil. and filters.
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Old 04-19-2007, 12:48 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Ramps are very FTW
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 04-19-2007, 09:10 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
one thing to thinka bout pits.. what if it rains? what if you drain oil into it.. O_o...
here in hawaii..what if you hit groundwater?! lol jk :P
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 04-20-2007, 12:57 AM
Who drains oil straight into the pit? Everyone i know, including me, uses a bucket.....oh, and yeah, i have a neighbor who has some really bad scarring on his face from being in a pit and having a spark ignite the grease and gas fumes down there. Lucky to be alive. He's really healed up quite a bit though. Would be odd seeing an outdoor pit.... Only ones i've seen are indoors, thank god, because the wind is a mofo where i live.
