Old 04-18-2007, 12:19 AM
ice745 ice745 is offline
AF -Advisor
Unhappy Killed me alternator
My alternator can't keep 14.5 volts anymore. It goes between 12.9 and 14.6 depending on what's on (headlights, high beams, wipers) It'll stay at a constant voltage without swinging, but that voltage always changes. I.E. it'll settle at 13.3 for a while. This is with the stereo completely off.
I'm going to replace the regulator, rectifier and brushes. Only 77k miles. I'm pretty sure my stereo had a good part in it.
I was wondering what is involved in buying a high output alternator, like Stinger or w/e. Do they come in OE fit sizes? How much modification is needed?
Thanks
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
Old 04-18-2007, 12:23 AM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: Killed me alternator
Generally, they don't need too much modification if at all, pretty much bolt on, but really depends on the vehicle though.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 04-18-2007, 12:25 AM
AF -Advisor
Thank you! Where can I go to get prices, and know which one is for my vehicle? How much do they go for in general, or does it vary a lot by car?
Old 04-18-2007, 12:30 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Mean-green.com
knuconcepts.com
or just type ho alternator on google.
I think your just drawing alot of current. AS you turn more stuff on your voltage will drop so that is normal. If i run AC, stereo, lights, wipers, and my electric fan i can run down to 12.9v. But i rarely run that much crap at once.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 04-18-2007, 12:38 AM
AF -Advisor
This alternator used to be very stable, 14.5 volts no matter what (with the exception of my stereo). Now it's 13.3 with just engine running, 14.6 with headlights on, 13.7 with high beams on, 12.9 to 14.6 with the wipers on. (The wipers now cause it to have similar fluctuation that my stereo does)
Something is definitely wrong.
And thanks for the links
Old 04-18-2007, 12:43 AM
I don't think anything is wrong either. However, the only thing an upgraded alternator hurts is your wallet (they will cost more than your stock one).
Old 04-18-2007, 12:50 AM
AF -Advisor
Before the alternator's voltage was unstable I had to charge my wet-cell battery ever week. Now I have Optima Yellowtop I have to charge every month. And I don't drive that often. That was when the alternator actually stayed at 14.5. Now that it runs at 13.3 I'll probably have to charge more often, or rebuild/replace the alternator.
Old 04-18-2007, 02:18 PM
PlayStation3 PlayStation3 is offline
is your car a import or a dometic cause most domestic need no modifaction besides wiring where imports it is more of a pain.
Old 04-18-2007, 02:49 PM
AF -Advisor
Toy Camry. It's a tiny denso type. H-O Alternators has a 170 amp OE fit for like $649, that's a lil bit out of me budget. Some E-Bay stores have rebuilt alternators they say are 160 amp for $140. I'm probably gonna try that, can't make me worse off.
Old 04-18-2007, 05:09 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Ohio Generator
Excessive amperage
Iraggi
try these too
