Old 10-15-2002, 12:02 AM
95civicman 95civicman is offline
reverse gauge install
how do you wire up reverse gauges in a 89 crx si?, thanks.
zc powered 89 CRX SI with some more stuff.
Old 10-16-2002, 09:52 AM
kaytec4door kaytec4door is offline
there is a couple of ways to get the power u can wire it into ur fuse box to the gauge fuse or u can wire them into the back of ur cluster because you will see a little possitive symble and negative symbles on the back. and remember the gauges go over your old ones.
:smoker2:kaytec4door:smoker2:
mods done: AEM cold air intake,
ractive racing cat,
ractive axel back exhaust,
NGK plugs,
nuespeed cross-drilled rotors,
EBC the green stuff pads,
projecter headlights,
clear corners,
carbon fiber tails,
Z3 fenders,
adjustable coilovers,
Konig flatline rims with dunlop fm901 (17*7),
full complete sound system with two 10'' subs,
kenwood 600w amp,
punch cap,
pionner speakers all the way around,
full custom interior paint job,
reverse indiglo guages,
aluminum gauge bezel,
d16a6 head swap polished,
4-2-1 ceramic coated header,
:finger4: proud member of team kay tec:finger4:
