Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 04-17-2007, 07:54 PM
Riot86 Riot86 is offline
i want a tach
i have a 2003 ford focus with a 2.3l duratec that came with no tach is there any interchangable cluster that has a tach already on it ?
Old 04-17-2007, 08:32 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: i want a tach
A cluster with a tach is not interchangeable. The cluster on that car is actually a module and requires programming to the rest of the vehicle's monitoring systems.
You will have to find a sensible aftermarket tach.
Old 04-17-2007, 08:48 PM
400sbc_guy 400sbc_guy is offline
Re: i want a tach
go to autoparts store buy a aftermarket tach. there are many types but id get the small sunpro and mount on steering column. very simple and quick to install. and they come w/ directions
Old 04-19-2007, 09:53 PM
BishiRST BishiRST is offline
Re: i want a tach
ok thanks now can you tell what wire to plug into on the harness (i have coil packs over each sparkplug so i have no distrebutor)
Old 04-21-2007, 07:03 PM
Re: i want a tach
there is a wire at coil pack either white or green. test with a test light and it will flash when running. this is the wire for tach.
91 s10 400 (484/494 cam)1.6 roller rocker,typhoon intake,800 cfm thunder avs carb,250 shot nos,5 speed,tubbed rearend w/ drags....chromed down 2 10in memphis hpo in a reg cab
Old 04-21-2007, 10:02 PM
Re: i want a tach
sweet dude, thanx//
