Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 04-17-2007, 04:02 PM
naif0391 naif0391 is offline
parking light problem
this may be a stupid question but the parking light wont work on the right front side of my 03 eclipse.the turn signal works, after it blinks a few times it starts blinking faster though.all the other parking lights are working, ive replaced the bulb and even swapped bulbs with the other parking light just to be sure it isnt a bad bulb. im not sure what it could be or how to fix it. any suggestions? thanks
Old 04-18-2007, 12:40 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: parking light problem
um...make sure the wires look good and that the whole assembly is in good condition with no cracks or anything. It might just be a bad unit and need replacing.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 04-18-2007, 02:41 PM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
are you using the stock bulbs? if you use an aftermarket bulb that has a different power value than the stock ones, that may explain the blinking faster since the blink rate is determined by the resistance of the bulb.
make sure the turn signal bulb has two lumens (kind of like those headlights with a high beam lumen 65watt and a 55 watt low beam lumen). if you look inside the bulb, you should see two lumens.
2007 Ninja 650R
2002 Eclipse GS
