Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 04-17-2007, 10:41 AM
blackcivicex blackcivicex is offline
help! pops when turned
i have a 98 civic ex and every time i turn really sharp it kinda pops and its hard to turn i just put new cv shafts in yesterday i was wondering if any one knows what the cause of the popping might be
Old 04-17-2007, 11:39 AM
jclark jclark is offline
Re: help! pops when turned
Make sure the shafts are seated into the transmission.
If not, you'll be able to pull them out by hand.
Pull and see.
If they're ok you need to check your ball joints and tie rod ends,
somethings loose.
Jack up the car and see if you can wiggle the wheel, look for play.
Also spin the tire and feel for roughness or noise, you could have a
bad wheel bearing. They'll do that.
That would be my first guess.
Jim C.
Old 04-17-2007, 12:08 PM
i will try that thanks for the help
Old 04-17-2007, 12:20 PM
You're welcome.
The front wheel bearing is "pressed in" on the 98 Civic.
If you need one, you'll have to dismantle everything and take the
yoke with the bearing in it to a machine shop and have them
replace it.
I did that last yr to my 98' and I think it was about $80.00 total
for labor and bearing for one side.
If you need one side, the other is probably close to needing
replacement too. This is a common thing.
You may need a puller to seperate the lower control arm ball joint,
AutoZone rents them out for free. Good luck!
Jim C.
Old 04-18-2007, 10:36 AM
i check all the ball joints tirods and wheel barings they all seem to be fine i called a mechanic he told me that the axle may not be all the way in i checked them and they where all the way in so i took them back and got a better set and it does the samething its hard to turn and it still pops it feels like the axles are binding up when i turn
Old 04-18-2007, 11:22 AM
You got me, I would have thought it to be one of the things mentioned.
I guess it's possible there's something wrong in the transmission.
You need to have it checked out, that's for sure.
Jim C.
Old 04-19-2007, 10:34 AM
i took it to a shop and they told me it was the tranny
Old 04-20-2007, 08:38 AM
NOSAJ's Avatar
NOSAJ NOSAJ is offline
The tranny wouldn't have anything to do w/ it poping when you turn left or right.
= your new CV joints
Old 04-20-2007, 08:44 AM
I disagree, the tranny very well could do that, especially a bad bearing
or gear n the differential part where it's straining to turn one shaft a lot
faster than the other.
Jim C.
Old 04-20-2007, 10:39 AM
it is the tranny its the diferintial i took it to the best tans shop in town and the looked it over and told me thats what it was so i got under the car and you can move the axles up and down and side to side while they are still in the trans and that is not good
