Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-17-2007, 09:48 AM
solar-eclipse solar-eclipse is offline
code deleating
one of my friends said he went to somewhere like autozone and they dealeted his codes or something and it made his car faster, is there anyhting like that, that can do that to your car?
Old 04-17-2007, 01:38 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: code deleating
No, deleting codes will not make your car faster, it just gets rid of the Check Engine Light.
95 Talon TSI AWD
97 Eclipse GST
Old 04-17-2007, 02:02 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: code deleating
No...and your friend should never talk about cars again. Deleting a CEL does nothing more than getting rid of the error code, it does not fix whatever problem he had to trigger the code.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-17-2007, 02:21 PM
subjec2failure subjec2failure is offline
Re: code deleating
when i first read this it sounded like someone deleted the governor on his ride. at least thats what i think its called, cause getting rid of that would let him get up to a higher speed. or i could be totally wrong
Old 04-17-2007, 05:15 PM
Re: code deleating
They might have messed with something in the computer system, but that's not possible on our cars. So no, you can't.
95 Talon TSI AWD
97 Eclipse GST
Old 04-17-2007, 05:35 PM
Re: code deleating
o true, well ya learn something new everyday.. lol
Old 04-17-2007, 10:25 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: code deleating
Well acutally, when the CEL gets reset, so does the ECU. So it may seem faster, depending on what's causing the problems to begin with. Like when my EGR throws a CEL every now and then, the car runs like crap. I get it reset, and then it's fine. The ECU is back in "learning mood". So it's grabbing info from all over again. Basically, fix what is causing the CEL and that'll get the car back running top notch.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-18-2007, 08:42 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: code deleating
Exactly. Different sensors require different drive cycles that may not result in the CEL being thrown for many miles of driving. Some sensor malfunctions cause the ECU to run the car in limp mode and kills the performance. Resetting the CEL resets the ECU, as david-b stated. This pulls the ECU out of limp mode and puts it back into normal operation.
Normally, problems that cause the ECU to drop into limp mode have extremely short drive cycles to keep the motor safe. It is very possible that resetting the CEL made the car run normal again.
Either way, you really need to stop driving the car because problems causing the ECU to run in limp mode need to be addressed.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-18-2007, 09:34 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: code deleating
i learned the hard way that if you delete the CEL it will show up for a SMOG test as having been recently turned off.
and the speed govn'r is a jumper on the ECU, a real life part, not a program code. take it off or move it and you are good for a bit more over 135. i got my car back from the shop and they forgot to hook up the speedo, so no govn'r. redlined 5th with the top down, 24psi on the gauge. fast enough to be scared. but a cool scared.
niiice.
Old 04-19-2007, 08:26 AM
Re: code deleating
You can either get a GSX ECU or clip resistors R255 and R256. These are the Configuration Resistors that control the governor.
1997 Spyder GS-T
5-Speed
