Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-17-2007, 07:55 AM
paulstalonesi paulstalonesi is offline
Fuel System Question
Hey guys,
Im starting to work on my 95 turbo now that i sold my 98 n/t. My car is running extremely shitty right now and is totally gutless. When you hammer on the car it feels like it wants to pick up then all of a sudden it will just die and then keep going really slowly. A guy i know that knows alot more about Turbo systems than i do did some research and he thinks that my fuel system is not big enough to support my turbo. My question to you guys is do i have to upgrade my entire fuel system(pump,injectors, lines, regulators etc..) or can i just recirculate the BOV and maybe the car should run like it should because it will be using the MAF sensor like it should be.
Any comments, suggestions or ideas would be much appreciated.
Thanks,
Paul
Old 04-17-2007, 01:39 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Fuel System Question
What kind of boost are you trying to run?
95 Talon TSI AWD
97 Eclipse GST
Old 04-17-2007, 02:48 PM
Im not trying to run any crazy amount of boost right now, i just want the car to run right and then take it from there. Right now im just running the stock boost.
Old 04-17-2007, 05:18 PM
Does it "stutter" when it starts to boost, or just "not boost"? If it "stutters" and then starts to pick up, replace the plugs with some regular NGKs.
95 Talon TSI AWD
97 Eclipse GST
Old 04-17-2007, 10:22 PM
The car doesnt really stutter, just when it wants to hit full boost it cuts out then continues on just as gutless as before it got to the cut out point.
Old 04-18-2007, 12:32 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
You are running a T4 turbo on 500cc injectors and a stock fuel pump?
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 04-18-2007, 01:40 AM
That was going to be my next question........ prick.
95 Talon TSI AWD
97 Eclipse GST
Old 04-18-2007, 04:39 PM
I think the injectors are only 400cc and yes the fuel system is stock.
Old 04-18-2007, 04:43 PM
Upgrade the injectors and pump ASAP! I wouldn't even want to drive it like that, I can't imagine the fuel cut you are hitting. Get a Walbro 255 and some bigger injectors. You'll also need something to control them, I suggest either an safc or if you can front the cash, go with link.
95 Talon TSI AWD
97 Eclipse GST
Old 04-18-2007, 09:31 PM
NOFX0617's Avatar
Yeah definitely replace both the injectors and fuel pump. I would also go with the Walbro 255 for the fuel pump. As far as injectors go I would probably go with at least some 660's but if you want to get everything out of that turbo you might want to go bigger. So that means you should probably go with DSMlink to control those bad boys.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 04-18-2007, 09:45 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
not to say that your fuel system is not cutting it, because you need some serious upgrades if you like the engine you have in the car now.
fuel cut is a violent thing. like 'OMG i just broke my car' violent. you would be on here thinking that you dropped a piston if that were the case.
also, misfires are like little fuel cuts, because fuel cut in itself is not fuel cut at all. the ECU drops the spark, so no scary bang in cylinder. you probably need new plugs anyways. NGK BPR7ES. accept nothing less.
also, check for a boost leak as well. it seems like you are getting a bunch of problems, but nothing all commanding, that all could be related to a boost leak.
boost leak tester
start with the free stuff and work your way thru it. boost leaks are most common at the BOV and IC pipe connections.
turn down the boost to 12psi and see what happens. you should be nowhere near fuel cut and misfires should not happen that low, unless you really have fucked up plugs.
Old 04-19-2007, 08:12 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
If you have a logger, you can take a look at your actual airflow and determine if you are out of injector. Could also be nasty knock which leads to the ECU jacking your timing. I had this happen a couple of times and it feels someone killed my acceleration.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-19-2007, 08:38 AM
WaFFeL WaFFeL is offline
Either way you should really upgrade your injectors and your pump asap. And an SAFC isnt a bad idea either
Old 04-19-2007, 08:45 AM
Thanks for all the suggestions.
Well i just got the recirculation adapter for the BOV valve in today. Right now the BOV isnt hooked up to the intake but hopefully by the end of the day it will and that will eliminate some of my problems such as the car not idiling when it warms up. As far as the fuel system goes, will i just be needing a new pump and new injectors? Or will i need new lines and a regulator? And in regards to the SAFC 2, is that highly recommended? Im kinda on the fence about the whole project because i was planning on selling the car mid-end of summer, so im not sure if i should spend the thousand bucks or go back to a stock turbo/manifold. Im interested to hear what you guys think in regards to this matter???
Old 04-19-2007, 06:03 PM
Pump, injectors, afpr, and safc/logger combo, that's what I'd do.
95 Talon TSI AWD
97 Eclipse GST
