Old 04-17-2007, 12:57 AM
MafiaAce MafiaAce is offline
Quick Question- No vacuum readout on Boost Gauge?
Hi all, just a quick question here.. I've been running my new manual boost controller along with a gauge for about a week now, its set at about 11 Psi (No higher until I get new spark plugs), all seems to be working well and fine. Only thing that has kinda bothered me is that I have never seen my gauge show vacuum, mind you-- yes it is a boost/vac gauge not just a boost one, but it is my understanding that after a shift the gauge should drop down momentarily to a vaccum as the extra boost is released by the BOV. Under medium acceleration the boost does drop after a shift ... to between 0-2 Psi, but I have never seen it go into a vacuum. Should this only occur on a truely hard shift at high Psi, or is this a possible indication that my BOV is not working properly or has a boost leak? I am confident that my gauge is installed properly etc and is air-tight, but should I be concerned about this at all?
Thanks.
1992 3000GT VR-4
Bolt-Ons In Progress
Old 04-17-2007, 04:29 AM
AutostradaVR4 AutostradaVR4 is offline
Re: Quick Question- No vacuum readout on Boost Gauge?
where do you have it reading the boost/vac from?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 04-17-2007, 07:38 AM
Hotshot8792 Hotshot8792 is offline
yea, make sure you have your boost gauge connected in after the throttle body
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 04-17-2007, 10:27 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
From this thread
http://www.automotiveforums.com/vbul...d.php?t=691878
Originally Posted by talskinyguy
second note, is it just a boost gauge? or is it a boost / vac gauge?
If its a boost / vac gauge it needs to be hooked up to a vac line that comes off the upper plenum / intake manifold after the throttle body or you will never read vac correctly.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 04-17-2007, 05:09 PM
Bah! I should read more carefully... my boost gauge was tapped before the throttle body at the y-pipe.... when it should have been from the plenum. Well I've switched it once again and am about to test it all out to make sure all is going fine.
1992 3000GT VR-4
Old 04-17-2007, 06:30 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
nice man that should help! haha goog luck!
Old 04-17-2007, 06:46 PM
Ahhh!! Despair continues.... now that my gauge is tapped into the Plenum Line, I'm only reading vacuum, no boost shows up at all when driving. Let me check if this is right... at idle it reads at about -15Hg, when accelerating lightly to medium around town I am staying in vacuum, the closest to boost I got was around 0 Psi... I am going to upload pics of the install in a minute as I am certain I have something hooked up incorrectly.
here we go:
As you can tell I dont have the gauge directly from the plenum, I split it off from that hose distributer...which I am uncertain if I even need... just left it there to be safe..
Before I was reading boost basically between the Y-pipe and MBC.. which seemed to work fine...
Maybe I am leaking boost with the new setup?
1992 3000GT VR-4
Old 04-17-2007, 07:59 PM
Ok, I located a leak coming from the other side of the vacuum hose that ran out of the plenum through the distributer and a ways down out of that to what I believe is the fuel pressure regulater...in short I replaced that hose so now its pressurized. Anyways,I do seem to be reading boost now though it doesnt seem to be much.... is a -16Hg normal for idle... and is a -10 to -5 normal for cruising? I did get it to go up into positive but even with heavy acceleration I dont think I really went higher than 6 Psi.... something just doesn't feel right. And I haven't touched my MBC, it still shows around 4 threads which previously the gauge read at around a max of 11Psi from the y-pipe.
Also I can definitely see the gauge drop to about -15 whever I put the clutch in. Should I just run a straight vac line coming out of the plenum T to the fuel pressure regulator? I've read the vacuum reduction mod but its left me somewhat confused... nonetheless my setup does look similar to this, 2nd picture:
1992 3000GT VR-4
Old 04-18-2007, 12:02 AM
you still have a leak somewhere
at idle, you should be sitting at -20, if your driving, then let off the gas, you should drop below -20 and then come back up to -20. If your having trouble building boost, you probably still have a boost leak somewhere. Where you tapped the line in does look correct.
Old 04-18-2007, 12:08 AM
Okay, I'll take a look once again tomorrow. In terms of minimizing the number of vacuum hoses, as in the reduction mod, is it safe to remove the entire metal bracket that sits on the throttle body and connects to the adaptors on the firewall, so long as I make sure the one line from the plenum goes to the fuel pressure regulator, or are there other lines that I would have to cap or run if I wanted to eliminate that?
Full guide is here http://www.3si.org/wiki/index.php/Vacuum_Reduction
Looking at that I dont want to entirely replace all my hoses, but I'd like to eliminate the bracket I was just talking about.
Thanks again.
1992 3000GT VR-4
Old 04-18-2007, 01:11 PM
normally what i do on a vacuum reduction is I pull all the solenoids, all the vacuum hoses in the area, the bracket on the throttle body and the long hard lines that run from the rear to the front of the engine bay. I then cap off the 3 nipples on top of the throttle body, run the nipple from the back of the intake plenum to the boost gauge, run the nipple on the back of the y-pipe to the inlet of the boost controller, run the outlet of the of the boost controller into a vacuum T and run those to the wastegates. Then I run a hose from the fuel pressure regulator to the nipple on the intake plenum thats located near the front side of the throttle body, then cut that hose somewhere in the middle, insert another vacuum T and run that to the blow off valve. Then I make sure that all EGR crap is pulled off and install EGR block offs. Thats it. However, those steps will be modified according to the emissions you have or what you are wanting to do. My steps get rid of everything.
Old 04-18-2007, 02:22 PM
Alright, after re-doing much of my vacuum line, I've finally located the cause of the leak itself... the back back of my stewart warner boost gauge actually. It turns out that the installation kit was supposed to include some type of ferrule for securing the tube lining air-tight to the back of the gauge.. unfortunately it did not come with such a device. I just tried tightening it and using a rubber barrier to create an air-tight fit, which did not work. So I just decided to glue the base of the fitting to the adapter with some PVC glue..now waiting for it to dry to see if that makes it airtight.
1992 3000GT VR-4
Old 04-19-2007, 05:22 PM
I've re done almost every single vacuum hose. The back of my gauge is now completely secure and airtight. Yet still I start up my car and idle at -16Hg. How can I still have a leak somewhere? I have check everywhere, the only other thing that comes to mind is I read somewhere that a screw on the throttle body can cause a leak as the rubber wears off....yet I have no idea which screw this is/ what they are talking about. I know where the idle RPM screw is, but I know that isn't where the leak is...
This is driving me crazy as I have been spending fay after day re-doing stuff and looking for leaks, my gauge installation is turning into a 2 week nightmare.
1992 3000GT VR-4
Old 04-19-2007, 05:40 PM
jason_bet's Avatar
I Havent been staying up to date with your luck.. but have you tryed putting it on the same line as your BOV? if not try that just for kicks
Old 04-19-2007, 05:44 PM
Igovert500's Avatar
blue + red light magnet
Easiest way to find leaks is to pressure test. Do a search, make a pressure tester, and pressure test. Easier to find leaks when you don't have to listen over the engine idling. Plus it will find leaks under boost that maynot be audible under vacuum. Chances are, if you havn't pressure tested before, you have quite a few, not just one or 2. The rear turbo/IC pipes' rubber gaskets, plenum gasket, biss screw's rubber O-ring, etc are some of the more common ones.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
