Old 04-17-2007, 01:24 AM
1987ss's Avatar
1987ss 1987ss is offline
kicker amp?
ive had a kicker 800.2 hooked up in my truck to two 15 L-7 kicker subs and today the amp shut down so i turned down volume and turned it back up and subs came on again.. any ideas? never done this before
Old 04-17-2007, 11:52 AM
Newbster Newbster is offline
Re: kicker amp?
Maybe your clipping?
Old 04-17-2007, 01:58 PM
1987ss's Avatar
Re: kicker amp?
what is that ? how can i correct it?
Old 04-17-2007, 02:04 PM
Re: kicker amp?
Adjust the gain level on amp, turn it down. Clipping means your turning up the volume too much and asking too much from your amp. Say your amp starts clipping at volume 40, if you lower your gain, you may be able to go up to volume 45-50 before clipping, etc...
Old 04-17-2007, 03:45 PM
1987ss's Avatar
Re: kicker amp?
Thanks im a try it
Old 04-17-2007, 04:40 PM
Automotive_Fanatic's Avatar
Automotive_Fanatic Automotive_Fanatic is offline
Re: kicker amp?
are you bridging the subs to a single channel? if so the you are probably running at the wrong ohms and the amp can handle it. thats what it sounds like. check and make sure that your wiring on the back of the subs is right. also that amp is designed for 4 ohms. not 2 ohms.
Old 04-17-2007, 07:29 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: kicker amp?
amp probably overheated ..... it's getting warmer outside
Old 04-18-2007, 01:31 PM
1987ss's Avatar
Re: kicker amp?
overheated? how do i prevent it? it only does it when turned up 2/3 of volume gain is about 1/4 the way up on amp...
Old 04-18-2007, 06:05 PM
Audio Guy
Re: kicker amp?
mounting and airflow ....... mine gets in the summer too
Old 04-19-2007, 12:46 AM
1987ss's Avatar
Re: kicker amp?
it was mounted to the box i took it off it today i noticed it broke two heads off the screws holding it to the box.. its a kicker kx 800.2 in and it is bridged to two kicker L-7 15's 4 ohms in series broke down to 2ohms.. i belevie... hit hard all up til a couple days ago.. i mean it hits still but certian songs it cuts out and comes back on..
Old 04-19-2007, 07:28 PM
Audio Guy
Re: kicker amp?
so the amp is seeing like 1 or 1/2 ohm per channel, could be why it's clipping and overheating .....
Old 04-20-2007, 04:19 AM
1987ss's Avatar
Re: kicker amp?
should i get another amp?
Old 04-20-2007, 06:07 PM
Audio Guy
Re: kicker amp?
the class D amps are typically mono (1 channel) and are designed to play low loads like that.
Old 04-21-2007, 04:10 AM
PlayStation3 PlayStation3 is offline
Re: kicker amp?
yea the class d that are full range are called icepower instead of class d because they help with the distortation of a class d.
Old 04-21-2007, 05:45 PM
Audio Guy
Re: kicker amp?
hmmm ... never heard of "ice power"
