Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 04-17-2007, 12:23 AM
94HeavyChevy 94HeavyChevy is offline
rear end question
recently swapped out my 4.3L L99 V8 in my 94 caprice classic with a Lt1 350. i want to change the rear end....should i try and find a rear to swap in or just get a ring and pinion set for my rear end, and what size gears should i get...i was thinking 3.73s or 4.11s, found a kit for both of those...kit is 250 bucks...rear end in it now is a 7.5 inch with 2.73s... would i face any computer problems? any help would be appreciated
Old 04-17-2007, 06:52 AM
Blue Bowtie's Avatar
Registered Offender
Re: rear end question
It might be better to try to find an 8½" rear end with the gearing you want. A small rear is not as likely to survive as well as a larger axle under a heavier car.
Old 04-17-2007, 10:35 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
If you go and get an 8.5" axle, you will need to get the driveshaft out of the donor car as well - the driveshaft needs to be 1" shorter.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 04-17-2007, 02:14 PM
463's Avatar
463 463 is offline
this may help you out: http://www.9c1.com/technical/engineapps.htm
Old 04-17-2007, 02:16 PM
463's Avatar
463 463 is offline
and a drive shaft link for you: http://www.9c1.com/technical/info/driveshaft.htm
Old 04-18-2007, 12:43 AM
so should i go with 3.73s in the 8.5 rear or bigger...and where can i find a 8.5 inch rear?
Old 04-18-2007, 01:07 AM
silicon212's Avatar
Confoundingly Lucid
Only if you don't care about fuel economy and have the engine built to run in the power band that this rear axle will give you.
The junkyards will be a great place to start.
Old 04-18-2007, 01:27 AM
Registered Offender
3.42 is a good compromise ratio between fuel mileage and acceleration with a LT1 in the B-cars.
