| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
New Engine
Hello guys got a question I have these 86 Z28 Camaro that I bought from this person he put in a 350 in it (swap from 305 originaly) I have been working on it here and there but still can't get it to pass smog. Now I 'm trying to save my money and buy brand new complete engine from maybe not to sure GM PERFORMANCE or somewhere else. What would be the best to get I'm looking in general performace and horsepower I heard about these LS and ZZ4 engines don't know too much about them and not to sure wether to go with carburator or fuel injected what would you guys recommend or suggest
THANK YOU |
Re: New Engine
Why won't it pass smog with the 350 it has now?
Re: New Engine
It's going to be alot cheaper to just fix the one you have now, than to buy a new crate from GM Performance...
![]() -2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*- |
Re: New Engine
I went to a smog shop to have a pre-smog done and the results were bad reasons that fail is because of the air injection, vacuum lines to sensors/switches disconnected, ignition timing fail but got these one fix I bought a timing light and move it to 8 degree that's according to the manuel book so don't know if it right because other book said 6 degree so which one is right. Some wiring sensors disconnected and the MIL /check engine light fail all other O.k. Also exceeded the gross polluter limits.This is why I was thinking in getting a brand new engine or else don't know too much about cars but I'm hanging in there doing what I can.
Another thing too is that the fuel gage is reding full and pass the full line so don't know how much gas I have went to junk yard got one replaced it and still does the same thing can't get an acquarate reading. Same thing goes for the oil gage needle shakes not steady so don't know what could be wrong and original computer if wondering. |
Re: New Engine
First off, getting a GM crate engine isn't going to solve any of your current problems. You'll still need to hook up all of the sensors, vacuum lines, air injection and set the timing on the thing.
If you have a TPI engine your timing should be 6 degrees BTDC (before top dead center) in drive (block the wheels and set the parking brake and for god's sake keep your and off the throttle) The check engine light is probably on because of all the things you say are disconnected. That is probably also the reason for failing for plllutants. A new engine also won't fix the fuel gauge being off or the oil gauge bouncing around. You need to start off by getting a repair manual for the car and figure out what all is disconnected and where it goes. Hook it all up. Set the timing. Disconnect the battery for a few minutes to clear all codes. Then take it for a drive and see if the check eng light comes on. If it does, pull the codes and go from there. |
Re: New Engine
![]() New engine will do you no justice wich is why I asked why it failed. Chances are Morley, seeing that the swap was done half baked, the EFI was ditched in favor of the goold ol "just throw a carb on it" mentallity, which could explain the fuel gauge problem too. Although, in '86 wasn't the HO still available? |
Re: New Engine
Thank you for your feedback guys. Let me clarify one thing about the MIL/Engine light coming on. It happened when the smog was being done not when I drive it around. But any ways I went to an auto wreck and got couple of wires and hookups that were missing from my 86 Camaro and plug then in, there's still some in there that I don't know where they go or what they do and like I said NO ENGINE LIGHT COMES ON when engine is running/drive around the block. Now I'm thinking in buying a SCAN READER /CODE READER to get all error code if any and hopefully follow that and correct any problems. So is that a good way for me to follow and have the emissions corrected and hopefully pass smog because like I said before the engine was swapped from a 305 to 350.
Re: New Engine
To get a clearer picture..Is this a TPI engine or the carbed version? To get your codes out you don't need a scanner or "code reader". You need a paperclip and the ability to count...thats it. Straighten the paperclip out then bend it in a U shape. Next locate your ALDL connector (driver's right knee just under the lip of the dash). Put the ends of the paperclip in the top right hand 2 holes (pins A & B). Turn the key to "on" but don't start the engine. You'll hear some clicking and the electric fan will come on, this is normal. Now, watch your check engine light. It should flash once, then pause and flash twice more. This is code 12 and it will flash it 3 times then move on to any stored codes. Each code will flash 3 times then move on to the next code until all codes have been reported and then it will go back to 12. Then turn the key off and remove the paperclip. As an example...a code 33 would be 3 quick flashes, a pause and three more quick flashes. Post any codes you find to this thread...along with which type of induction you have (TPI/Carb). The biggest problem with people doing a swap from 305 to 350 in a 3rd gen is they don't put in a calapck for a 350, or if they do the 350 has a bigger cam, different heads, etc, than the stock 350's that came in the cars that had 350's. Another thing people don't do is they don't put in a 350 knock sensor. |
Re: New Engine
O.k. did the paper clip to get the trouble codes if any and didn't get anything at all not even these 12 code which is the shake hand with the computer. So I don't know if there is any trouble code at all or if there's something wrong with the computer. Also discover my brake lights does not work properly and what I found out is that with the engine off I press on the brake lights and the light comes on, start the engine press on the brake and light comes on and at same time my instrument panels and these is with headlights off, turn headlights on and the brake lights doesn't work at all. So can somebody tell me what could be wrong.
Re: New Engine
You could try a new (junkyard) ECM and see if that atleast gives you back your code 12. IF not, you have wiring problems. Your brake lights are also a wiring problem or possibly a combination of burned out lights. Check all bulbs for proper operation and then go from there.
Re: New Engine
So itereating the same question previously asked, what type of fuel delivery does this thing have??? |
Re: New Engine
O.K. it's a carburator one and to let you guys know I just replaced the computer and this one seems to be working because I actually can know get these 12 code (BLINK puase BLINK, BLINK) nothing else happens after that it just keep repeating. But know I don't know what happen with the car because it won't stay on it actually turns off after a few seconds. I thought it was the new computer I put in but it's not because I put the old one back in and it does the same thing. Do you guys know what could be this time. New comp back on no trouble code reported.
Re: New Engine
Good news on getting code 12 back. A couple quick questioins. When it shuts off, will it restart right away? When it shuts off does it sputter and shake first or does it just die?
If it won't restart right away and sputters as it is dieing, I would say get the ignition module checked. If that checks out good, get a spark plug and pull one of the wires and hook it to the plug. Hold the plug against a good ground (engine block or other bare metal) have someone try to start the car and look at the spark color. If it is orange or red, you have a problem with either the primary coil or secondary coil. If the spark does check good, then it must be a fuel delivery problem. Possibly the pump isn't putting out enough fuel volume and or pressure. If the module checks bad, only replace it with AC Delco, the off the shelf brands are junk and will fail in less than a month. |
Re: New Engine
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
Re: New Engine
