Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-16-2007, 07:57 PM
400sbc_guy 400sbc_guy is offline
Exclamation 96 eclipse rs backfire when gave gas
i just bought a 96 eclipse rs 2.0 non turbo auto trans. it needed a ecm and a crank sensor. cranked up and ran great at idle but when u give it the gas it fired out exh at 2500 rpm. i cut the cat. off and straight piped. but still fired out exh at high rpm. put on snap on computer and no codes. replaced ngk plugs with new ngks.still getting fire out exh. this car is pissing me off to much electronics. someone help!!!anyone!!!!!
91 s10 400 (484/494 cam)1.6 roller rocker,typhoon intake,800 cfm thunder avs carb,250 shot nos,5 speed,tubbed rearend w/ drags....chromed down 2 10in memphis hpo in a reg cab
Old 04-16-2007, 08:29 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 96 eclipse rs backfire when gave gas
Dude, I asked you if you had a CEL (Check Engine Light) in your previous thread. Please, do NOT make duplicate threads on the same problem.
95 Talon TSI AWD
97 Eclipse GST
Old 04-16-2007, 09:01 PM
didnt under stand what u asked...sorry!!!. the check engine light is not on.
Old 04-16-2007, 10:05 PM
Have you checked the TPS yet?
95 Talon TSI AWD
97 Eclipse GST
Old 04-16-2007, 10:33 PM
no i havent. how do i check this?. it idles great.im not much on mpi. i deal with carbs more.
Old 04-16-2007, 11:23 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Try this
http://www.geocities.com/MotorCity/D.../dsmtests.html
You can also check in a shop manual if you have one. It should tell you how to test it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-17-2007, 07:47 AM
thanxs. im gonna check now
Old 04-17-2007, 10:56 AM
tps is ok. i replaced with new one and no change
Old 04-17-2007, 01:40 PM
When you cut off the cat you didn't mess with any of the o2 sensors did you?
95 Talon TSI AWD
97 Eclipse GST
Old 04-17-2007, 03:02 PM
no still connected
Old 04-21-2007, 07:31 PM
any other ideas...im totally lost!!!!!
