i have a 03 dodge neon se it was starting rough took it to the shop it was plugs had it for bout a month it was doing it again took it back to the shop it was fuel pump got it back no more rough starts but when i stop at a light it will sound like its about to stall let off the brake and it stops im just anoyed by this prob conserding i drive 200 plus miles per week to and from work
Re: my 2003 dodge neon se
Might have a vacuum leak somewhere (loose hose). Check all your vacuum hoses and clamps.
2003 Dodge SRT-4 |
tried that and nothing cars at the shop now
mabye i looked over the stuff were is all the vacume lines its a 2.0
Just A Idea.. get some Choke spary..run motor then check for bad vac if you haven't already done so...also Check your Throttle position sensor (TPS) JUST A THOUGHT..Hope it helps
