Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-16-2007, 03:15 PM
dcx96 dcx96 is offline
Angry cylinder misfire
My 99 JGC limited with 4.0L has a #3 cylinder misfire what does that mean and how do i repair that, is it just a spark plug or coil or is it worse.
Old 04-17-2007, 07:25 AM
dell520's Avatar
dell520 dell520 is offline
Send a message via Yahoo to dell520
Re: cylinder misfire
Check your spark plug wires and plugs, also check the distributor cap. I'm not sure how the 99 looks under the hood, but it should be similar to the 97 I have.
I had the same problem once and it was my distributor cap. Hopefully it's just a loose wire. Good luck.
Old 04-17-2007, 11:41 AM
No cap just a long coil I'll change the plugs and Map sensor but theres no wires either, the chrysler manual suggests that after that it may be a bad exhaust valve at cylinder 3 damn I hope not. I inform later.
Old 04-17-2007, 05:36 PM
Cool Re: cylinder misfire
I fixed it, bad plugs bad carbon so I'll decarbonize the combustion chamber thrusday then done.opcorn:
