Old 04-15-2007, 11:36 PM
jjh1976 jjh1976 is offline
multi function switch
hello again fellas how is everyones taurus?
my multi function switch is being goofy i turn on the wipers and i have to wiggle the stalk to get the wipers to work. when i wiggle the stalk i can hear a relay clicking. has any one encountered this. i replaced the switch with a used one but still the same problems
Old 04-16-2007, 12:41 PM
Millermagic Millermagic is offline
Re: multi function switch
Sounds like a wiring issue. I'd check the wiring around the stalk.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 04-16-2007, 01:38 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Did you replace the multifunction switch or the stalk? The electrical contacts for the wipers, washers, and intermittant delay are in the stalk. These contacts may be dirty or damaged.
What year is your Taurus? I disassembled and cleaned the stalk on my '93 SHO years ago and took pictures along the way and wrote up the steps I performed. If you'd like me to send the doc your way, private message me with an e-mail address for you that can accept attachments.
-Rod
Old 04-17-2007, 11:15 AM
donclark70 donclark70 is offline
I had a similar problem with the wipers not working, then the turn signals quick working. The contacts were all pretty dirty, so I cleaned them up (spent about an hour doing so), then managed to get the whole thing back together. The turn signals worked, but then there was some other piece that didn't work (don't remember what it was now).
I ended up just buying a new multi-switch. I remember it being a little pricy, but everything worked then.
My repair manual also said to disconnect the battery and then remove the ignition cylinder - so the airbag doesn't go off while working in the steering column.
