| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
boost problem.
i have a 92 tsi with a evo 16g turbo with a boost controller, autometer boost gauge. and i was wondering why my boost will not go over 10 psi even when the controller is turned up all the way and i dont think there is any leaks... it is so confusing me.. i dont get fuel cut either..
Re: boost problem.
This should be under the subforum "Problem Diagnosis"... I am going to say that you need to check your vacuum lines. I think one has popped off, and this will limit you to stock boost. I had this happen to me awhile back, I can't remember which vac line exactly, but I think any of them will do it...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
Re: boost problem.
Do a leak check.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Re: boost problem.
oh sorry about using the wrong forum.. and i will be going home and checking my vacume lines and doing a leak test tonight.
Re: boost problem.
OK i done a boost leak test and i got air flowing threw my pcv (it is new) and that is about the only leak that is left to make any problems... is there any way to just block off the hole into the manifold and put a filter on the pcv? i feel stupid a lot sry guys.
