Old 04-15-2007, 04:56 PM
Don Mason's Avatar
Don Mason Don Mason is offline
NO sound out of rear speakers
When I adjust the fade to the rear only, I get no sound whatsoever out of the speakers. Anyone else had this problem? Advise? TIA -Don
Old 04-15-2007, 06:38 PM
gmpartsman gmpartsman is offline
Re: NO sound out of rear speakers
A few questions...
Is it a factory radio? What year is your TB? How long has this been happening? Did the rear speakers EVER work?
Might help in answering your question.....
Old 04-15-2007, 08:37 PM
Don Mason's Avatar
It is a 2002 with the stock am/fm cd cassette. I am unsure if the speakers ever worked. Last week we were on a trip and the kids wanted more music in the back than we did up front. when I adjusted the fade to rear only, I lost all sound. I have never attempted to adjust the fade before the trip.
Old 05-02-2007, 07:49 AM
ff-racer ff-racer is offline
I recently had the sound go out in one of my rear speakers. When I removed the door panel, I found the speaker full of water! The other speaker had some water damage also. I have replaced them with Sony XS-V160HP speakers with plastic cones. The swap was easy without any door mods.
Old 05-02-2007, 12:35 PM
rodeo02 rodeo02 is offline
Originally Posted by ff-racer
..When I removed the door panel, I found the speaker full of water! The other speaker had some water damage also. I have replaced them with Sony XS-V160HP speakers with plastic cones...
Hope those Sony's are water proof! You might want to fish thin wire or the likes through the belly drains on the doors to make sure they drain properly. You always get a small amount of leakage through the outside window belt.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 05-03-2007, 03:22 AM
Joel
Great idea! I have a small solder iron I can melt a small hole thru the cone to prevent tearing. Thanks
Old 05-05-2007, 02:14 PM
max3456's Avatar
max3456 max3456 is offline
Send a message via Skype™ to max3456
After reading your post I checked my rear speakers and the drivers side does not work. I removed it and found possible water damage. I checked the wires for signal and it present. I guess it is time for replacement speakers. I beleive 6.5" will work. I can't beleive GM would put such cheap Mexican speakers in a $33000 SUV.
Anyone have any recommendations for a replacement set? From what I have read Polk seems to be the brand I will buy.
Darrell
2006 HHR LT 2WD Metallic Blue
Ecotec L-2.4 175 HP
4-spd Auto
Old 05-05-2007, 10:56 PM
fortcarp fortcarp is offline
According to crutchfield.com they are 6.5s, I was wondering if the speakers were any better quality with the Bose system? I am prolly gonna upgrade mine as well, check those drain holes and water seals while the door panels are off. The Infinity 6.5 should sound awesome with the Bose.
Carp
'03 TB LT EXT, Black
Old 05-07-2007, 09:37 PM
Anyone know where to get the adapters needed for the GM speaker connectors to aftermarket speakers?
Carp
Old 05-07-2007, 10:28 PM
max3456's Avatar
I am just going to cut them off and connect new ones for the new speakers. Anyone know which wire is the positive lead?
Darrell
Ecotec L-2.4 175 HP
4-spd Auto
Old 05-09-2007, 02:53 AM
The speakers are 6 1/2". Crutchfield has a good sellection finder and offers adapter kits when required. I had to cut 2 small plastic pins off the door panel. The wiring diagram can be found here:
http://www.installdr.com/Harnesses/GM-Wiring.pdf
