Old 10-14-2002, 01:50 PM
Redline_civic91 Redline_civic91 is offline
Send a message via Yahoo to Redline_civic91
signs u need a new clutch???
what are they?? the reason im wondering is because when i had my stock engine and tranny i would bearly have to tap on the clutch and i can shift gears. when i got my swap it was the same thing for about 2 weeks. now if i bearly push on the clutch it wont go in. i have to almost push it to the floor to change gears. does that mean i need a new clutch.
91 civic b20/vtec=sold
95 acura integra=sold
02 chevy silverado=totalled
95 honda accord=please i hope nothing happens to this!
Old 10-14-2002, 05:30 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
well, there is a couple of ways that i have used to tell if my clutch is going on me....or slipping. From a dead stop, let the clutch out slowly without giving it any gas. Watch the tach, and when the rpms dip a little then you know that you have reached the friction point (you may move forward a bit). If it reaches the friction point when the pedal is almost completely released (very high up)...then your clutch is probably going or you need to adjust it. To adjust it, you need to turn the black plastic adjustment knob on the clutch cable (right where it hooks on close to the transmission itself) clockwise, i think. If it is able to be turned in that direction, then turn it a couple of times and retest it like i described before. It should reach the friction point/engage sooner now.....if you were able to adjust it at all. Another way that you can tell if your clutch is going or slipping (this is by no means good for your car) is to power shift it (keep the gas pinned) into 2nd and listen to how many seconds it slips for. When my clutch was going i had somewhere between a 5 and 10 second slip...my clutch was pretty bad. well...i hope that this helped out some
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 10-14-2002, 05:31 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
You are supposed to push the clutch to the floor to change gears. Partially pushing the clutch in wears it out real quick.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 10-14-2002, 06:36 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
yea it does...i learned that real quick
Old 10-14-2002, 09:29 PM
Cfmotorsports's Avatar
Cfmotorsports Cfmotorsports is offline
Send a message via Yahoo to Cfmotorsports
Who Needs A Frickin Clutch:frog: speed shift it makes your clutch last long time:flash:
MY MONEY PITs!!!
2001 Silverado-----------90 Civic Si
4.8 V8---------------------ZC DOHC Power
K&N------------------------Intake
2" in the back-------------3.5 Eibach
Rollin on 20's--------------15" AR wheels
Pioneer head--------------Panisonic head
JL 10w6--------------------Infinity Ref
http://community.webshots.com/album/49425207zKoYto
Old 10-15-2002, 01:07 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Im thinking about welding the flywheel to the presure plate and hunting for the gear and to stop hmmm turn the motor off. put in gear and start it again to go. sounds good to me
