Old 04-15-2007, 11:42 AM
Divorce Court Dan Divorce Court Dan is offline
Send a message via AIM to Divorce Court Dan
97 park ave vacumn build up in motor
after runing for a couple of minutes the car counds like a pulley bearing is squealing when you take the oil cover off on the valve cover there is alot of vacumn pressure and the noise stops help
Old 04-15-2007, 12:21 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 park ave vacumn build up in motor
Anybody replace the pcv recently?
Old 04-15-2007, 12:31 PM
yes brand new
Old 04-15-2007, 03:36 PM
A990 racer
Make sure both o rings are in place for the pcv, there is a large one under the map and a small second one on the pcv.
Old 04-15-2007, 03:40 PM
OK. Will do. Let you know how it goes.
Old 04-15-2007, 09:29 PM
madman8874 madman8874 is offline
The O Rings Are There I Have Never Had A Car That Builds Vaccum Like This One Any Other Thoughts
Old 04-15-2007, 09:36 PM
97 P/a Major Vaccum Build Up
I Have A 1997 P/a That Was Making A Sound Like A Pulley Was Siezing I Took The Oil Fill Cap Off And There Was A Major Amount Of Vaccum And The Noise Went Away If I Put Cover On Noise Is Back I Checked Pcv It Looks Like New And O Rings Are There What Next
Old 04-15-2007, 09:43 PM
BNaylor's Avatar
BNaylor BNaylor is offline
You wouldn't by chance be Divorce Court Dan? I see your IP addresses match. You are aware you are only allowed one AF account? No second or alias accounts. Sorry but I'll let you keep one account but one will have to be terminated.
Timeslip 08/12/06
AF Community Guidelines
Old 04-15-2007, 09:51 PM
Nope I Am Not Him Sorry HE IS A FRIEND OF MINE
Old 04-15-2007, 10:00 PM
BNaylor's Avatar
Are you using his computer? I see your IP address matches his right now. It didn't make sense for Divorce Court Dan to post the problem and then you come on like it was him. Do you see my point?
Timeslip 08/12/06
Old 04-16-2007, 12:35 PM
A990 racer
I'd try another pcv.
Old 04-22-2007, 09:26 AM
dw5600 dw5600 is offline
Re: 97 P/a Major Vaccum Build Up
Check the whole pcv system, you must have a clog. If you keep running it this way you may cause some real damage.
