Old 04-15-2007, 11:40 AM
mjtr21 mjtr21 is offline
Instrument Cluster Light
Does anybody know how to get the tachometer needle off? The light that lights it up is burned out and I would like to replace it. I had the one right in the middle of the instrument cluster burn out and I replaced that one, but I don't know how to get to this other one. I also have to replace one of the HVAC lights that lights up the LO speed and the Windshield Defrost. Also would anyone know the light numbers? I know the one for the Instrument cluster that I replaced was 194 but I think these are smaller. Thanks.
Old 04-15-2007, 12:03 PM
DINO55's Avatar
DINO55 DINO55 is offline
Re: Instrument Cluster Light
You should not have to pull the tachometer needle off to change the light. The light's are mounted behind the dash cluster in little holders, simply twist the holder and pull it out.
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 04-15-2007, 12:15 PM
yeah that's the way I replaced the other light but for this one I cannot see anything from the back of the cluster. I pulled it right out of the truck and looked at the back of it. The ones I can get to are for warning lights, and the center light. I cannot get to any of the other ones.
