Old 04-15-2007, 11:32 AM
callmewhatyoulike callmewhatyoulike is offline
Question Cranking but not starting sometimes.
2001 F150 5.4, this is a hard problem to define. Every so often when you go out to start the truck it doesnt start but it will crank. Then if you wait about 30 minutes and try again it runs fine. Has recently had a new fuel pump and filter, and alt. put in. problem stayed the same. When you turn the truck off the check engine, water, and oil lights lights, and little dashs across the odometer light up and stay on until you press in the brake pedal. I let the lights stay on for a couple hours once to see if they would shut off on there own but they didnt.
Old 04-15-2007, 11:32 PM
Torch Torch is offline
Re: Cranking but not starting sometimes.
Your truck should have the OBD-II system, buy and/or borrow an OBD-II scanner box and see if any codes were tripped and stored in the engine computer, data jack should be under your steering wheel somewhere.
Old 04-16-2007, 12:23 AM
I've had other cars checked by autozones little computer thing, is that the same thing?
Old 04-16-2007, 12:50 AM
Yeah, same thing.
Old 04-16-2007, 06:06 PM
they said it had no codes? Also forgot to mention the battery gauge and the fuel gauge stay active on the dash until you press the brake?
Old 04-16-2007, 09:14 PM
westieforplumbing@ westieforplumbing@ is offline
If you have a after market remote start I would check that or disconnect it I have had problems with mine when I disconnected it the problem went away good luck
Old 04-16-2007, 10:02 PM
Nope dont have one of those but thanks anyway!
Old 04-11-2008, 12:39 AM
bryant_kelly2007 bryant_kelly2007 is offline
okay i have a 95 ford f150 does anyone know how to replace the clutch switch on it or where it is located i could really use the help
Old 04-11-2008, 08:14 AM
FNA FNA is offline
Cranks no start
Sounds like short in ignition system - two shorts really suince one causes 'hot lights' to stay lit after you shut down and the other causes intermittent no start.
Mebso a relay because the 'hot light' problem is solved by activation of brake light circuit.
Seek to fix the hot light problem first, other may follow
Old 04-11-2008, 08:17 AM
FNA FNA is offline
Clutch switch
With HYDRAULIC CLUTCH LOOK NEAR THE CLUTCH MASTER CYLINDER.
Old 04-11-2008, 08:19 AM
FNA FNA is offline
With a hydraulic clutch look near the clutch master cylinder. With a mechanical clutch, look near the pedal.
Old 04-21-2008, 02:40 PM
jwall77 jwall77 is offline
check your spark plugs maybe there fouled out, and u said the filter and pump were changed? maybe the pump has a short sumwere, and ya check the ignition sytem to
JWALL77
