Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 04-15-2007, 10:28 AM
zolemite's Avatar
zolemite zolemite is offline
1998 Gas door
For some reason my gas door does not open with the button or the manuel override. I just bought the car the other day and you can see where the guy used his key to open the door. When I bought it you had to use the manuel override plus the key so I took the latch off so you can just use the key. I'd like it to work properly and have no idea where to start. It appears that the release mechanism works properly just the door doesn't pop open.
Old 04-16-2007, 09:49 AM
Towncar's Avatar
Towncar Towncar is offline
Re: 1998 Gas door
There's just a small spring missing. It doesn't open all the way with the spring, just enough to get your hands on it. Check your local dealer for the spring, have 'em order it if necessary. You might be able to make one if someone with send you a detailed photo or two.
-Steven
1996 Town Car, Cartier
Old 04-16-2007, 10:02 PM
zolemite's Avatar
Re: 1998 Gas door
Thanks for the info. I just like my car right. I'll look into that spring. You wouldn't know the part # by any chance?
Old 04-16-2007, 10:23 PM
Towncar's Avatar
Re: 1998 Gas door
Originally Posted by zolemite
...You wouldn't know the part # by any chance?
I've looked at the drawings very closely looking for a spring, I don't see one. There appears to be a button looking thing protruding from the top of the fuel cavity opening, towards the door. Do you have something like that on yours?
I think what I'm describing is the spring. If not, it may be a door ajar switch, but I don't see any further details on it.
OHHHH CONTI GUYS, WHERE ARE YOU ?? Tell you what zolemite, if we don't get some other Conti guys in on this thread soon, you might want to jump over > here < and ask about that spring.
-Steven
Old 04-16-2007, 10:27 PM
zolemite's Avatar
Re: 1998 Gas door
Thanks. I used to own a prelude and a focus andthere was tons of info in those forums. Which was great.
Old 04-24-2007, 05:09 PM
Soaripmama Soaripmama is offline
Re: 1998 Gas door
Hey there,
I had the same issue with my '96 Continental and was able to purchase the part through my local Ford dealer (about $10) and installed it myself. Good luck!
Old 04-24-2007, 10:21 PM
zolemite's Avatar
Re: 1998 Gas door
what part is it???
Old 04-25-2007, 01:22 PM
Re: 1998 Gas door
I don't remember the part number. It is just a small piece of metal, folded in hald that acts as a spring to open the door. When it was broken, we had to pull the manual override (in the trunk) and open the door at the same time. If you call a Ford dealer, their parts department should be able to find the part number for you. I was not able to find it online, so had to order it from a dealer.
Good luck!
Old 04-26-2007, 08:13 PM
jbrown413 jbrown413 is offline
Re: 1998 Gas door
i have the exact same problem with the same car. i use my credit card wedged between the fuel filler door and car body, which works now. hoping it is just a cold weather problem. will find out tomorrow as the thing wants more gas.
if you find out the part number please let me know. thanks -- joe
