Go Back   Automotive Forums Car Chat > Dodge > SRT4 > SRT4 Problem Diagnosis
Old 04-15-2007, 09:42 AM
fast_driving2007 fast_driving2007 is offline
Damn Im Pissed...!!!!
I Raced Twice Last Night To A Cobalt Supercharged And A 2007 Gti..
And As Soon As I Would Shift To Second They Would Walk On Me Like Krazy....does Anybody Know Wat Would Be The Case????
They Were Both Stock...my Srt Has Just A Intake And A Blow Off Valve....could It Be The Weight Of My System????
Old 04-15-2007, 05:44 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: Damn Im Pissed...!!!!
Fast_Driving2007, we need to work on the way you post. Please post in the proper section for your question. The main forum is only for questions that don't seem to fit in with the other two listed sections.
That asside, you most likely need the "driver mod." The two cars you named have somewhat comparable times to an srt4 and a bov and intake will not give you much of an advantage...and a heavy "system" just sets you further back.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 04-15-2007, 10:09 PM
93hondab16 93hondab16 is offline
well i have no prob. beating them. and im pretty much stock. if u know howto launch the car and shift smoothly u should be winnin. i was runnin 14.1 stock and the cobalt and the new gti run 14.7 stock i think. u might have a boost leak. maybe one of ur lines came off. happens.
Old 04-15-2007, 10:34 PM
your right i do have a boost leak...i was looking at my boost today and it would only go up to 5psi in every gear.....i hear like a wistle when i hit the gas.....than when i go wot in second gear and change at red line i only get 5lbs of boost....does anybody know how to fix dat????
Old 04-15-2007, 10:44 PM
well u know that sticker under ur hood. tellin u were all the lines go. check every single line on there. check all ur intercooler piping. who installed the bov. they might not have installed it right. just make sure everything is connected. i had problems wit the lines by the turbo. and the brake booster.
Old 04-16-2007, 12:23 AM
i checked everything and it was the intercooler piping...its loose.....thanks 4 da help...
