Old 10-14-2002, 11:38 AM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
So Much Detail??????
in most of the itr ive seen there has been soo much detail in the engine and everytime i try to get so much detail it come out messed up, like in the pics above the line are so perfect and even the H and the VTEC are done perfectly how do u people do this? and it has a dipstick and even a ground wire WOW!!!!!!!!!!!!!please can someone give me som etips as too how i can make my engine come out to look this good
Rui
(modeling) = Click Here
Old 10-14-2002, 11:56 AM
nubiannupe's Avatar
nubiannupe nubiannupe is offline
Send a message via ICQ to nubiannupe Send a message via Yahoo to nubiannupe
What I'm trippin' on is that CF cold air intake! The rest of that, I did on MY ITR, but I wanna know how da flock did they do THAT???
G. Rick (a.k.a. Tha "R") 93 Maxima SE
- PETER NORTH IS MY IDOL!!! -
81-00-65 42-54-00 93-04-97-24 (my phone# - if you figure THAT out, you can call me...) STILL GOT A BAAD ATTITUDE!!!:
Old 10-14-2002, 12:44 PM
Guiddy's Avatar
Guiddy Guiddy is offline
The tip you are looking for is experience and practice, the two things that can't be bought I'm afraid!!!
It just comes with time and lots of model building! Be patient, and it will come. Never rush model building either, that shows. He was patient as each of those colours dried off in that engine bay.
Which looks awesome BTW! Very impressive!
Old 10-14-2002, 01:23 PM
Joe Ortiz's Avatar
Joe Ortiz Joe Ortiz is offline
Very nice!!
Old 10-14-2002, 01:25 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Also, study pictures of the real ITR, both normal and tuned. You have to know something about real car's engine and other parts when detailing a model.
Wiring comes down to five major categories, such as, electrical wires, air hoses, hot and cold water pipes, fuel lines, and various oil tubes(engine, brake and ABS). (Am I missing something?)
Identify those lines, and organize yourself, and the detailing work would be somewhat less complicated.
Hiroaki Fukuda
Old 10-14-2002, 01:42 PM
Lownslow's Avatar
Lownslow Lownslow is offline
for starters you need a "pinvise" with lots o drill bits.and you need some wire i use 20 to 24 gauge for spark plug wire (still figuring out the accuracy of both on engines) and 30 gauge for small engine spark plug wire. i started detailing a while back, im still working on the engine after that its brake lines and such
Old 10-14-2002, 04:17 PM
well what should i use to get s good paint job on the little tings like the VTEC lettering and all of the other hard o paint areas
Rui
Old 10-14-2002, 07:26 PM
like do people mask of the areas on the engine or do u just use some special little thing:frog:
Rui
Old 10-14-2002, 07:41 PM
935k3's Avatar
935k3 935k3 is offline
That engine looks like it has had Bare Metal Foil applied on the middle of valve cover and the letters. One way to do the letters is to cut a small piece of BMF and apply it before painting. Then after painting you rubout rhe paint until the foil shows through on the top of letters only. Small details can be picked out with toothpicks and paint. Sometimes it is necessary to mask. And if possible it always better to airbrush parts. If an engine bay has allot of black parts they usually vary in the amount of shine from gloss to satin and flats and that needs to be replicated. Try to paint in a way that parts look like they are made out of some material not painted. Some lettering can be done by dry brushing(dip brush in paint then touch to tissue to remove most of the paint) over the top of letters.
Old 10-14-2002, 08:03 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Bump that bare-metal-foil job! To make sure it comes out perfect, smooth and lightly even-out the letter height with a 4-way file before you foil them, works every time!
The CAI is easy - Get some large-diameter solder, cut, bend, and shape it (it's very malliable) and apply c/f or kevlar decal strips - done!
One more solder trick - get various rolls in different sizes (as many as you can find!) and they can be used for many different wires, hardlines, etc. just paint them... My favorite is to roll them with a flat file at a 45 degree angle, bend to shape, and paint them silver. This makes for incredible and dirt cheap braided-steel hoses, just add fittings!
My AF Classic Model Car Gallery
Old 10-14-2002, 10:57 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Re: So Much Detail??????
if you read his thread, he explains everything that he does, even the H and VTEC. What he did is painted it silver, and then painted red over it. Then he scraped the red off of the VTEC and H with a little knife.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 10-15-2002, 03:30 AM
wkma7six wkma7six is offline
Wow!!!!! Somebody's using my pics as samples The intake pipe is not CF!!!! Its Carbon Kevlar!!!! The decals are from Modelers of Japan. The engine was painted Silver first then the red. Read the past posts in the first thread.
And thank you Kicker1solo for clearing that up. I don't know how many times people have asked , but doesn't seem like anyone wants to read the past threads/posts.
-Walter
BTW, that is not a cold air intake pipe. Its part of the Turbo system piping. There's a Turbo, Wastegate, and blow-off valve in the pics.
Old 10-15-2002, 02:51 PM
Jay! Jay! is offline
Horizontally Opposed
Being trained as a Honda Tech doesn't hurt either, I'd imagine...
Hierarchy of Subaru:
(Click to see mine!)
